Mounting fuel filter
runawy9
Post by runawy9 »
Is it acceptable to mount a canister style fuel filter in the engine compartment?
I want to move it from under the car off the frame to clean up the look from behind my car.
I was wondering if it's ok to put it on the fire wall with a heat shield around it?
ProPower engines
Re: Mounting fuel filter
Post by ProPower engines »
What kind of pump are you running and what fuel is being used??
runawy9
Post by runawy9 »
Aeromotive ss pump.
-8 line from pump to engine.
Pump gas
ProPower engines
Heat is an issue as well as engine parts exiting are the only thing to be concerned about hitting it or lines would be my only concern.
You want the fuel filter at the back of the car, mounted/plumbed before the electric fuel pump on a street car.
Get a smaller body size fuel filter. The common $10 OEM type inline paper element fuel filters
flow HUGE volume. That huge body fuel filter is mostly show hype.
It's pretty looking but not better.
Get a suitable normal good OEM style inline fuel filter and flow test it in your on car fuel system on your car and see. Spend $10 and replace it once a year.
Ted Gerstenslager
Post by Ted Gerstenslager »
If you end up at the track then you will probably be bounced in tech. No fuel system or components to be mounted on firewall.
cgarb
Post by cgarb »
Every stock fox body mustang at the track should be bounced in tech too I guess? The factory fuel supply and return lines run across the firewall and into the back of the engine to the fuel rails.
91stang
Post by 91stang »
cgarb wrote:Every stock fox body mustang at the track should be bounced in tech too I guess? The factory fuel supply and return lines run across the firewall and into the back of the engine to the fuel rails.
Pretty sure they come up from the front of the engine...
1991 mustang 3040 with driver all motor all the time 9.70 @ 138.75 1.31 60' street driven mufflers and real tires, mt 275/60/15 radials with a 950hp holley.
cgarb
Post by cgarb »
It did on my 84 but that did have the throttle body style injection.
jsgarage
Post by jsgarage »
Most race Tech inspections frown on pressurized fuel containers due to the possibility of fires, and that extends down to autocross. The single exception is an all-factory setup and you may have to document that for some inspectors. Regardless of where an actual filter is mounted, it should be BEFORE the fuel pump so you don't have a container of gas at 45+ psi (or even 6 psi with a carb). Those are more properly called "bombs".
cgarb
Post by cgarb »
Float bowls? Carbs they mix air and fuel...atomic bombs.
Geoff2
Post by Geoff2 »
The fuel filter should be after the pump.
'Never use any kind of filter-other than a simple screen- on the suction side of a fuel pump.' From the original Holley book written by Holley engineers.
In-Tech
Post by In-Tech »
100 micron on the inlet side of the fuel pump, 10-40 micron on the outlet side of the fuel pump depending on whether efi or carb.
-Carl
cgarb
Post by cgarb »
Holley must be good at engineering bombs...lol
Geoff2 wrote:The fuel filter should be after the pump.
This is false and it makes no sense... You want the fuel filter before a electric pump to keep dirt out of the pump.
The filter does not restrict flow at all. You read too much.
