After some Out of tube #s I decided that more srr work, more ave loss.Ported Chevy 049 heads
Re: Ported Chevy 049 heads
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
That would be Pitot tube ssr #s! Not spell check b.s.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Recut 60 degree throat cut and slight polish on ssr. Slight gains.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Boat tail removed.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Removed boat tail.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Removed boat tail. This will be very thin and not accepable for racing or street use. Just looking for flow gains. Bob took lots of metal out of the roof to make the boat tail.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Flow aftr boat tail removal.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Since my gains on these heads are zero I decided to increase the bowl ratio and see if that helped. It didn't.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Increased bowl ratio to 91.7%
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
increased bowl ratio on exhaust as well. All three bowls had a good amout of material removed. No help.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Slight gain on straight port, slight loss on hook and exhaust over original flow averages.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
I decided to take a good amount of material from the cylinder wall side of each intake and exhaust port looking for gains.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Gains on both intakes loss on exhaust.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
From what I have read you have a 45-60-75. What is your top angle?
Do you have a backcut on the valve? Very interesting, thanks for the pictures.
Bob did a 30 - 45 - 60 valve job. I added a 75 throat cut and lost flow so recut the 60 and shrank the 45. It was a bit wide anyway. The valves are Bob's as well and look like no back cuts.Old School wrote:From what I have read you have a 45-60-75. What is your top angle?
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
