Experience w/ Rebco Machine piston mods?
BradH
Post by BradH »
Looks like the "smart" choice is probably to have my new flat-top pistons modified for D dishes to lower the CR to stay pump-gas friendly with the smaller chambers of new heads I picked up. Rebco Machine in Kansas has some piston mod videos posted online and can definitely do the work. Any experiences of people on here dealing with them? Thanks, Brad.
Dragsinger
Re: Experience w/ Rebco Machine piston mods?
Post by Dragsinger »
Yes, my experience is excellent, good shop doing good work.
vortecpro
Post by vortecpro »
Very solid to deal with.
user-9274568
Post by user-9274568 »
At one time everything that came from Patterson Racing was from Rebco. Now it's all done in house.
IMO, begins and ends with Rebco.
Travis Horton
Post by Travis Horton »
Rebco is great and very affordable.
wyrmrider
Post by wyrmrider »
send them a mold of your chamber or a templet and they can match great to work with
bigl1971
Post by bigl1971 »
I have used Rebco on several projects. Always does a fantastic job and has quick turn around.
Brian W
Post by Brian W »
Rebco is quality service, top notch!!
bigfoot
Post by bigfoot »
If you tell what cylinder head..can they machine the dash to match the head ?? Does this make more HP ?
wyrmrider
Post by wyrmrider »
big
thats controversial
I always thought yes and seems so with early sbc and bbmopar 915 head with tight quench (maybe plug location)
however on a turbo build with d cup we found quench area was too large and blowing out the fire
think quench vs squish
many modern heads have two or more quench pads
DCal
Post by DCal »
The really great thing about Eric is that he does all these processes without screwing up the ring grooves Some shops are not so good.
WeingartnerRacing
Post by WeingartnerRacing »
Eric is amazing and quick. Highly recommend.
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
Dave Koehler
Post by Dave Koehler »
DCal wrote: Fri Feb 28, 2020 1:23 am The really great thing about Eric is that he does all these processes without screwing up the ring grooves Some shops are not so good.
Please explain how others might screw up ring grooves.
Other than paying attention what does Rebco do differently to avoid ring land screw ups.
DCal
Post by DCal »
Dave Koehler wrote: Fri Feb 28, 2020 9:35 am.,
Distorting the grooves by clamping the part too hard, three jaw chucks, or if holding the pistons by an air fixture- too much pressure. If using chucks they should be indicated in and trued up and more jaws than 3 is preferred. How Eric does his must be a secret Dave but I think he fully understands aluminum.
Dave Koehler
Ok, as expected paying attention to details, good fixturing and being one with the aluminum is all that is required.
I was worried that there was a new thing that needed to be implemented.
