CamFlowRPM version 2.1 not computing
Faster
Post by Faster »
Problem with this software from Jon Schmidt.
It seems that most people can run this version of camflowRPM without problems.
I downloaded this version from speedtalk and what it does is opening and computes just once.
After that is doesn't compute anymore when i change one of the inputs.
I asked Jon about his but he cannot help me here because of the java problem.
I am not a java programmer or a software guy.
So my question to the users of this program is: How does it work on your pc ?.
I tried many old java versions and none of them could cure the problem.
Also i tried various operating systems and no progress here either.
Has someone any idea why this failure is there ?
Tkx,
JS
"You have your way. I have my way. As for the right way, the correct way, and the only way, it does not exist."
SchmidtMotorWorks
Re: CamFlowRPM version 2.1 not computing
Post by SchmidtMotorWorks »
Make sure that there are no empty fields and that there are no spaces or no European commas instead of decimals.
RevTheory
Post by RevTheory »
I can't even get mine to unzip or basically do anything but I'm blaming that on my wretched Windows 8. I've been through the whole Java deal several times with several browsers, got confirmation that Java is updated and correct and still nada...
I'm sure I'll wake up one morning with a fancy new Windows 10 update (that I don't want) so we'll see what happens then. I can see it now, "oh look, CamFlowRPM works but my printer, video drivers, etc. don't. Fantastic..."
SchmidtMotorWorks
RevTheory wrote:I can't even get mine to unzip or basically do anything but I'm blaming that on my wretched Windows 8. I've been through the whole Java deal several times with several browsers, got confirmation that Java is updated and correct and still nada...
It was zipped using 7-zip, if you don't have that app, you won't be able to unzip it.
7z has become the default zip application for most people involved with software that I know.
Windows 10 is much better than any version of 8, in many ways it is more like windows 7.
RevTheory
Post by RevTheory »
Good to know, Jon, thanks. I may give it another run later.
F1Fever
Post by F1Fever »
Personally I think .zip is much better bc it comes default and the compression savings aren't worth using 7zip
here it is in a standard ZIP file, hope it works:
http://www.filtrex.org/turbo-s10/CamFlowRPM2.zip
also I've noticed if you change a data point in certain cells you have to click out of the cell in another cell for it to "save" it and display a new graph
I was no longer driving the car consciously. I was driving it by a kind of instinct, only I was in a different dimension.
West Siloam Dispensary
Rizzle
Post by Rizzle »
win zip only uses 1 thread to compress, 7zip compresses using all (or most) of your cores. Once you start to zip large files, this becomes a huge time saver.
F1Fever
Post by F1Fever »
a file like this zips in under a second and is easily opened by almost any user. JMO
RevTheory
Post by RevTheory »
That link did the trick F1, thanks.
statsystems
Post by statsystems »
Evidently it is not Mac compatible. Bummer for me.
SchmidtMotorWorks
statsystems wrote:Evidently it is not Mac compatible. Bummer for me.
JAVA does support Mac but I never compiled a Mac version.
Now that the development environment is no longer supported there is no way for me to compile a new version.
That happens sometime when you use a new/emerging language and development environment.
SchmidtMotorWorks
That was one of the frustrating thing with those UI tools at the time.
Chipster
Post by Chipster »
I assume this also applies to ubuntu/linux also?
Thanks
SchmidtMotorWorks
Thanks
Yes, I only compiled it for Windows.
Hard to imagine not owning at least one Windows computer.
wyrmrider
Post by wyrmrider »
you could have used FORTH
