515 BBC Build/Straub/Foxwell
bob460
Re: 515 BBC Build/Straub/Foxwell
Post by bob460 » Wed Mar 25, 2020 4:35 am
vortecpro wrote:
Tue Mar 24, 2020 10:23 pm
bob460 wrote:
Mon Mar 23, 2020 11:07 pm
What ever happened with this build?
The car went on to run 9.04 @ 148 @ 3580 NA 10 inch tire. The owner died of cancer, the car was given to his friend, the friend ran the car for a few years, and now the engine is back at Straubs for a rebuild/new engine.
Thanks for response, sorry about the loss.
Finally a car that ran the true numbers with the dyno numbers.
Do you know the converter and rear gears it had?
Also how streetable do you think it could be?
Thanks, Bob
vortecpro
Post by vortecpro » Wed Mar 25, 2020 9:18 am
Thanks, Bob
3.90 gear, Turbo 400, Can 9 inch converter. It wasn't streetable, 13.1 comp, valve spring killer, hows it possible to run 7500 RPM through the lights with a 2.300 stainless valve with 550 LBS open spring pressure with a .903 heavy lifter? I wanted titanium valves and solid lifters.....nobody else involved did, thats why Davie died running 9ohs instead of 8.80s
