L48 Project: Ported Chevy 450 heads vs. Bowtie vortec heads
Carnut1
Re: L48 Project: Ported Chevy 450 heads vs. Bowtie vortec heads
Post by Carnut1 »
viewtopic.php?t=48390#p638441
DV. E7TE thread that these heads are from.
631-816-4911
9:00am - 9:00pm EST
Elroy
Post by Elroy »
Carnut1 wrote: Mon Aug 05, 2019 1:30 pm9.1 comp
Carnut1 wrote: Mon Aug 05, 2019 1:30 pm Crappy headers
Carnut1 wrote: Mon Aug 05, 2019 1:30 pm 34 degrees timing
Carnut1 wrote: Mon Aug 05, 2019 1:30 pmno tuning
Carnut1 wrote: Mon Aug 05, 2019 1:30 pm Intake valve is really too big for that casting
Your not much of a salesman are ya? :lol: . Just messing with ya. I am not finding where the dyno info or power numbers are stated....is it somewhere in the thread you linked?
Carnut1
Post by Carnut1 »
Elroy wrote: Mon Aug 05, 2019 2:47 pm
The two day dyno test was planned for many heads tested on same shortblock. We got to test a stock E7 set, A modified RBJ E7 set with Stud RR 1.6, This set of E7's with stock sled rockers and 1.6 rr, and a set of DV modified gt40 aluminum heads. So the only heads that got the timing changed was the RBJ heads. I would have liked more runs to tune and the high lift hydraulic roller cam that these heads were designed for. Hopefully DV is well enough to finish this head shootout. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 »
download/file.php?id=20012&mode=view
Lets see if this works.
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 »
I see it was a Quick Fuel 750 carb not a 650.
631-816-4911
9:00am - 9:00pm EST
Elroy
Post by Elroy »
Carnut1 wrote: Mon Aug 05, 2019 3:28 pm Hopefully DV is well enough to finish this head shootout.
3 sets of heads in 2 days is going to be hard to do and have enough time to learn a ton from without going 24hr shifts. :D
Wouldn't you have to reoptimize cam timing for each set of heads to find conclusive results?
Carnut1 wrote: Mon Aug 05, 2019 3:28 pm Hopefully DV is well enough to finish this head shootout. Thanks, Charlie
I would assume that will have to take a back seat to his REC entry.
Carnut1
Post by Carnut1 »
Elroy wrote: Mon Aug 05, 2019 4:12 pm
The original schedule was more intense than that. It would have been nice to fiddle with cam degree and spark timing for each head. DV and I had a long discussion on the rec mill on the car ride from N. Carolina to Virginia for the dyno testing. It will be interesting! Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Elroy
Post by Elroy »
Carnut1 wrote: Tue Aug 06, 2019 8:01 am It would have been nice to fiddle with cam degree and spark timing for each head
To each their own but I can't imagine removing one set of heads for another before finding at the very least best timing....cam position. That is a very basic simple thing to nail down. Am I missing something here? What was the overall objective in this... in that these kind of remedial things were not done....out of time? Im going to assume that I'm missing part of the story..no biggie.
Elroy
Post by Elroy »
Come to think of it...I just realized I am continually referring to an engine not mentioned in this thread....I did not intentionally try to derail. The download didn't work for me and I still don't see the dyno sheet or power curve listed in the other thread. I will look through it again. My apologies.
Carnut1
Post by Carnut1 »
Elroy wrote: Tue Aug 06, 2019 10:00 am Come to think of it...I just realized I am continually referring to an engine not mentioned in this thread....I did not intentionally try to derail. The download didn't work for me and I still don't see the dyno sheet or power curve listed in the other thread. I will look through it again. My apologies.
I was able to put the dyno sheet up without a link. The plan was 8 sets of sbf heads in two days. Even for long days it was known we would not have time to maximize every combo.
631-816-4911
9:00am - 9:00pm EST
gmrocket
Post by gmrocket »
Carnut1 wrote: Tue Aug 06, 2019 10:06 am dv charlie e7.jpg
Just think how mixed up we are? That 41 page thread , a dyno sheet and all kinds of plans talked about...
I'll ask again, anything out there with your heads on it ,,running hard that will knock our socks off?
I tried googling your head development ,all I got was that 36 second vid of the Ford on the dyno
Carnut1
Post by Carnut1 »
gmrocket wrote: Tue Aug 06, 2019 10:37 am
No, website has not even been a thought. I have done a bit of work for ST members maybe they will chime in. I have a few projects in the works but nothing I can share. Think of me as you will.. it matters not to me. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
gmrocket
Post by gmrocket »
Carnut1 wrote: Tue Aug 06, 2019 11:43 am
Carnut1 wrote: Tue Aug 06, 2019 10:06 am dv charlie e7.jpgI was able to put the dyno sheet up without a link. The plan was 8 sets of sbf heads in two days. Even for long days it was known we would not have time to maximize every combo.
Can't think anything of you if there isn't anything to check out. Seeing how you've posted about a hundred pics of your port work, I was thinking there would be something out there making some good power.
Thanks, Dale
gmrocket
Post by gmrocket »
When is DV on the dyno that week? He was on the list before but I don't even see his name listed now....
He's doing a SB Ford right?
Carnut1
Post by Carnut1 »
gmrocket wrote: Tue Aug 06, 2019 9:48 pm
Thanks, Dale
Probably nothing that would impress you. Just for fun you could post up your EMC Olds 307 dyno vs. this 306 and see how I did. I do love that you guys did up an Olds. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
