Yes, all CNC from billet.midnightbluS10 wrote:Didn't Steve Morris recently do a V16? For the Devel Sixteen
http://www.enginelabs.com/engine-tech/e ... 16-engine/
build a bigger engine the hard way
Re: build a bigger engine the hard way
2 x 215" seems like a lot of trouble to get something with fewer cubes, more weight and less HP potential than a punched-out SBC...
One fit nicely into the back seat of my '52 split-window VW back in the early sixties...
No, all homemade. A machinist friend had built a Renault-powered formula car with a VW trans and when the 4 cyl. blew, he shoehorned in an Olds 215. The car was destroyed in a crash soon after, and looking at the wreckage I said "Hey Tony, why don't you put it in your old VW?" He replied "Don't be ridiculous!" but by the next spring he had done it. A year later I traded in my '57 Morgan on it and terrorized the town for a couple of years before selling it to go back to school.
- Location: In the Darkness, where Fear and Knowing are one
An adapter plate could bolt the front of one block to the back of another. Bolt a flange to the crank output of the front engine and use that to drive the crank snout of the rear engine. The rear engine might need a custom crank to be able to transfer enough torque into the snout to work. Other than that, it's just two engines. Need to figure out a way to feed coolant to the rear block, but once the connections are figured out, it could be via a second waterpump in the accessory drive on the forward engine.ericjon262 wrote: ↑Fri Dec 16, 2016 1:30 pm I've seen a couple of these done, and was thinking about one day, doing it myself. with two V6's for a 7-ish liter V12 the hard part I see, is welding the heads and blocks together lots of preheat and jigging, obviously you'll need cams ground and a crank made, engine management could also get a little tricky as there aren't many V12's out there, maybe aftermarket.
anyone done it before? got any pointers? here's a couple examples using V8's.
One of my favorite responses to crazy ideas on car forums comes from this... "If you think you can do it, you don't need the internet to tell you how". Works for both end of the skill spectrum...
Building a v8 from two Hayabusa engines seems common enough to rather look into putting together two inline sixes on the same crank.
Perhaps there is a way of joining such engines together by running the head studs to a common crankcase after the mains have been milled off.
I've heard of both mounting BMW 24V I6 heads on a BMW V12 block as well as mounting 24V Jaguar heads on a Jaguar V12 block.
As Porsche demonstrated with the M96/M97 and incessant IMS bearing failures, using the same head on both sides of a DOHC engine results in some monkey motion of the timing drive
what a blast from the past! this project is still in my head, but I won't be making any real progress on it for a few years.The Dark Side of Will wrote: ↑Mon Mar 16, 2020 12:12 pmOne of my favorite responses to crazy ideas on car forums comes from this... "If you think you can do it, you don't need the internet to tell you how". Works for both end of the skill spectrum...
I mainly asked the question because different people come up with wildly different solutions for the same problems, some of which are easy, many of which are hard, it's nice to have the internet available for learning from someone else's successes and failures.
Something different in the way of an engine MIGHT be a MEL 534 put on an acid diet to lighten it. Mill the decks to 90 degrees and install some modern REWORKED heads on it so that it can breath.
As well as one of the great big V-6's that if not mistaken, GMC made through the years for trucks. Acid dip one of them too...
Those giants are cool, but not really concentric with the final goal for the engine. the end point of the engine would be that it gets put into a car reminiscent of a 1960's F1 car.
