Have you ever actually tried to lighten a block by acid? If not, don't bother.
build a bigger engine the hard way
Re: build a bigger engine the hard way
- Location: In the Darkness, where Fear and Knowing are one
I was thinking that 3/4 or 1" steel plate could be lasered or water jet cut into shapes that would both be main bulkheads and receive the head bolts/studs (they'd have to be pretty long, but that's the point). Wider pieces of aluminum could be sandwiched in between. Dowel everything together, seal the joints with RTV or linear O-ring stock and run high strength threaded rod through the whole thing and you have an assembled crank case.ericjon262 wrote: ↑Mon Mar 16, 2020 7:10 pmwhat a blast from the past! this project is still in my head, but I won't be making any real progress on it for a few years.The Dark Side of Will wrote: ↑Mon Mar 16, 2020 12:12 pmOne of my favorite responses to crazy ideas on car forums comes from this... "If you think you can do it, you don't need the internet to tell you how". Works for both end of the skill spectrum...
I mainly asked the question because different people come up with wildly different solutions for the same problems, some of which are easy, many of which are hard, it's nice to have the internet available for learning from someone else's successes and failures.
Carve cylinder blocks out of billets, dowel them in place, then drop shelf Darton (Caddy 4.9? ) or similar wet liners into the cylinder block to seal on the aluminum chunks of the crank case and you have yourself an assembled engine block. Hopefully you even designed it to work with your favorite cylinder head.
