Ported Ford 289 heads with port energy discussion
hoffman900
Re: Ported Ford 289 heads with port energy discussion
Post by hoffman900 »
MadBill wrote:I'm not advocating that approach, merely providing a numerical answer to your flow-based pipe size question: "So is a flow chasing 53cc 1.6" valved exhaust that flows 170 cfm oversized for a relatively high rpm 289? Flows about 190 cfm with a 1 5/8" pipe. Thanks, Charlie"
As per my previous response, I believe pipe size comes first. Theories on the subject have certainly evolved over the years. The factory race system (developed in the late forties/early fifties) for the Vincent 61 c.i. V-twins I raced in the sixties was a pair of 2" x 54" pipes and a number of 30.5" singles in the pre-war era ran dual pipes of ~ 1.5". #-o
This.
A friend of mine talked with his old, late friend Mark Donohue at length about the AMCs. They tried all sorts of sizes on primaries on the Javelin motors with no difference, so they used what was most easily available. We know WAAAYYY better now and engines of that size with similar power are running primaries two sizes smaller. This totally means the ports they were using back then were way too big.
Post by MadBill »
FWIW, with all else equal, if you input a higher V.E. into the PipeMax program it of course estimates more power but also suggests a slightly smaller pipe. :-k
randy331
Post by randy331 »
digger wrote:
MadBill wrote:Update:
I found a graph by David Vizard in his How to Build Horsepower book; it also can be seen about 1/4 of the way through his Max Small Block book as seen here: http://www.chevydiy.com/chevy-small-blo ... t-systems/
The chart suggests pipe size vs. exhaust flow. For a street/strip engine with 170 CFM flow, a pipe ID ~ 1.60" is shown.
that methodology for choosing pipe size would perpetuate the issues of an oversized port. i think pipe size has hardly anything to do with port flow on a flow bench.
I'd say optimum ex pipe size has nothing to do to do with what the ex port flowz on a bench.
Those types of ideas are based on theory only.
Randy
digger
Post by digger »
MadBill wrote:FWIW, with all else equal, if you input a higher V.E. into the PipeMax program it of course estimates more power but also suggests a slightly smaller pipe. :-k
mine doesn't, an increase in VE needs more pipe size and the same size as when VE is kept same but peak hp rpm is adjusted to give same hp
e.g. 6800rpm with 110% equals same size as 7511rpm with 100% both have same predicted hp number and pipe size within 0.001". so pipemax primary pipesize is very very strongly correlated to peak hp
Post by MadBill »
The info I quoted is from a PipeMax v. 3.7. I've got a newer version filed away somewhere that I haven't loaded yet; guess that's one of its refinements so I better get it cranked up..
CGT
Post by CGT »
mag2555 wrote:With a duel pattern Cam and compressions above 11.5 even a 68% Exh to Intake ratio as shown in flow bench testing will work well many times!
What book or article did that information come from and what is well? Absolutes spoken on very dynamically complex processes tend to trip my
b#!%&*t alarm.
GARY C
Post by GARY C »
Maybe time to start measuring exhaust performance with a sound frequency measurement SFM as oppose to CFM.
Stan Weiss
Post by Stan Weiss »
b#!%&*t alarm.
Unless things have changed very recently. The 2.9 - 3.0 HP per ci N/A NHRA (500 ci) and Australian Pro Stock (400 ci SB's) are running closer 60% Exhaust to Intake ratio.
mag2555
Post by mag2555 »
Not only that fact like Stan posted , but look at some of these great performing heads with like a 2.19" Intake valve and yet still just a 1.65" Exh.
These Heads are a built in 70% or less Exh to int ratio no matter how you slice it!
Carnut1
Post by Carnut1 »
Hp/cube and rpm make a difference here. Available differential pressure makes it that the intake valve takes presidence so you see larger and larger intake valves and better c/d intake ports. The exhaust valve and ports shrink and even though pumping losses increase for the exhaust the engine still makes more power.
631-816-4911
9:00am - 9:00pm EST
randy331
Post by randy331 »
b#!%&*t alarm.
Those kinda comments are about as comical as 2-3 deg of LSA is worth 30-50 pounds of TQ.
Randy
user-9274568
Post by user-9274568 »
Pipemax recommendations can be spot on for headers. Lengths, and sizes....
David Vizard
Post by David Vizard »
I mentioned this before a year or so ago but intake to exhaust ratios are entirly dependant on the CR.
DV
David Vizard
cspeier wrote:Pipemax recommendations can be spot on for headers. Lengths, and sizes....
Chad,
It is really rare that I disagree with you but for the engines we most commonly deal with all the commonly used programs are far from accurate.
DV
Warp Speed
Post by Warp Speed »
Weird huh?!? Lol
