432" SBF build.
cjperformance
Re: 432" SBF build.
Post by cjperformance » Thu Oct 19, 2017 11:48 pm
bigjoe1 wrote:
Thu Oct 19, 2017 10:13 pm
MUCH BETTER CHOICE
JOE SHERMAN RACING
Yes, the 1st cams i posted were VERY cheap pickups. Initially budget said 1 of them would get used but enough cash was saved on other parts to allow a bit of an upgrade thankfully.
Craig.
cjperformance
Re: 432" SBF build.
Post by cjperformance » Wed Nov 01, 2017 7:07 pm
Well the 432 is all together and in the flesh looks real good all in satin black. No bling on the whole car, white and satin black, looks really cool. I will get some pics sent on the weekend.
Unfortunately my phone memory card died and i lost all the pics in my phone with only the last shot prior to wrapping it up and rolling it out to the trailer saved in my phones memory which is a bummer. But i hear its now in the car almost ready to start and will be at the strip on sarurday for a few soft passes to check the car and licence the driver.
Craig.
KnightEngines
Re: 432" SBF build.
Post by KnightEngines » Wed Nov 01, 2017 7:37 pm
Nice!
statsystems
Re: 432" SBF build.
Post by statsystems » Wed Nov 01, 2017 8:09 pm
Yup...I love satin black. Looks very cool.
cjperformance
Re: 432" SBF build.
Post by cjperformance » Wed Nov 01, 2017 8:43 pm
Thanks guys.
Yeah i like the satin look. Im not into shiney stuff, i had a show bike years ago and it put me off cleaning and chrome and polished alloy for life ! Haha.
I have 2 more on the go for the satin look.
A 308 holden all satin like the 432 then a 408 clevo all satin but this guy knows a chrome plater and his car , XT Falcon, is mat black with convos and all the bumpers, chrome and stainless trim done in satin chrome. Its about to be assembled but is looking awesome. He has had stock clevo "power by ford" valve covers done in satin chrome aswell, they look great. Something a bit different
Craig.
tuffxf
Re: 432" SBF build.
Post by tuffxf » Thu Nov 02, 2017 3:27 am
Nice! Like the black!☺
cjperformance
Re: 432" SBF build.
Post by cjperformance » Wed Nov 08, 2017 7:00 pm
Well Mat got the car out to the track, much suspension sorting required which in turn will help traction. Main thing is he had a ton of fun, it ran strong (apart from the starter drive gear falling off at one point !) and he started to get used to driving it again and even with a near idle speed foot brake launch(has a PG, trans brake + 2 step) and a 5200 shift into top gear with a lot of peddling still managed to get a PB at 6.66@106 with a lot of driver nerve settling and HP usage still to use.
Craig.
tuffxf
Re: 432" SBF build.
Post by tuffxf » Wed Nov 08, 2017 7:30 pm
Way to go Craig!
Steve.k
Re: 432" SBF build.
Post by Steve.k » Wed Nov 08, 2017 7:47 pm
Looks good Craig. You guys will get it dialed then hang on.May i ask why you guys like the shorter rocker on exh?
cjperformance
Re: 432" SBF build.
Post by cjperformance » Wed Nov 08, 2017 8:05 pm
Cheers Paul thanks mate.
Steve this ended up with 1.6 rockers intake and exhaust.
To me the different rocker ratios are simply a handy tool to manipulate the valve lift curve. You can in short get 4 slightly different 'grinds' out of one cam by using 1.6/1.6, 1.6/1.7, 1.7/16 & 1.7/1.7.
So if stuck with a cam thats not the best for the combo you can just play with how the valve sees the lobe. Same as changing roller lifter wheel diameter.
Once suspension is sorted and he can go consistent full power runs then I'll do some new pipes for it. There was no time to modify the pipes so we used an AFR header flange between the heads and the traditional windsor port shape on his pipes as a makeshift adaptor to soften the mismatch ! #-o as the AFR port is quite different and a lot wider than the normal windsor port. So theres a little gain to be had down the track once he can use it.
Craig.
Steve.k
Re: 432" SBF build.
Post by Steve.k » Wed Nov 08, 2017 8:16 pm
Ok i see. I thought maybe running into clearance issues on exh. Seems to work real well. Afr seems to have good product i have never used. Everyone i see using there stuff run well.Good work.Whose heads on clevor?
cjperformance
Re: 432" SBF build.
Post by cjperformance » Wed Nov 08, 2017 8:31 pm
Ok i see. I thought maybe running into clearance issues on exh. Seems to work real well. Afr seems to have good product. Everyone i see using there stuff run well.Good work.
Yes the AFR stuff is good for sure, no fitting issues, good consistent port alignment. Had to cut/weld the guide plates for tip alignment but thats pretty normal and almost nothing is perfect there without a chop n' tig!
But clearance issues on everything else with the 4.250" crank ,, :lol: man a 4.170" crank falls into these but that extra bit creates a LOT of extra work. All part of the fun!
Craig.
cjperformance
Re: 432" SBF build.
Post by cjperformance » Thu Nov 09, 2017 1:26 am
Steve, sorry i missed this bit of question , heads on clevor?
Craig.
BigBlocksOnTop2
Re: 432" SBF build.
Post by BigBlocksOnTop2 » Thu Nov 09, 2017 5:41 am
Nice and early spring down under.
cjperformance
Re: 432" SBF build.
Post by cjperformance » Thu Nov 09, 2017 5:50 am
Well the seasons here have been kind of all over the place, iirc the last day of winter was beautiful and sunny and the 1st day of spring was cold and wet, temps since then have been up and down like a honeymooners nightdress ! :lol:
Craig.
