And left POWER and torque on the table because you did not try the larger carbs.andyf wrote:The Edelbrock recommendation of dual 500 carbs is a good one. That combo will work really well. I've used the dual 500 cfm setup on multiple engines with excellent results.
The larger 2x4 carbs ALWAYS outperform the 2x 500's.
Some motors really like a COMBO style carb spacer. It can help equalize the air speed of the upper and lower planes of a dual plane manifold yet main the the SPLIT 180deg plenum.
Like this one..
Edelbrock carbs like Wood spacers for fuel bowl heat control.
If you search on facebook there is a guy who make up a COOL 2x4 carb spacer ADAPTER that allows
installing TWO holley 4 BBL carbs, inline on this exact Ford SB dual quad RPM manifold using the small holley fuel bowls. It is possible on the Ford.
He was smart and his 2x4 Holley to AFB dual quad spacer adapter has split 180degree plenum design.
The Edelbrock-- Carter AFB`s or AVS (thunder series) give up nothing to holley carbs on this one soo.....
