4vpc wrote:ptuomov wrote:modok wrote:I'm not an expert on it, but usually knock does happen most often at the edges of the chamber by the intake valves, and looks to me like they fill-in those areas and makes them more like quench areas, putting more volume by the plug and exhaust vavles and less at the far side of the intakes, and it actually works. Many other designs, blue flame, may-fireball, sure does work, and for the same reasons.
Of course, that means intake valve clearance at TDC can be a problem, but if you don't NEED a lot of overlap then it's quite practical. Short stroke, big valves, turbo......you don't need much overlap.
Don't tell the subaru guys. Putting a turbo on that glass house should be discouraged
I believe knock happens on the intake side of a four valve head for the following reason. The tumble motion drives the flame to the exhaust side. Exhaust side then burns first. Knock is ignition of the unburned end gas. Since the exhaust side burns earlier because of the tumble motion, the unburned end gas has to be on the intake side. It's like the old joke about why do you rob banks having the answer because that's where the money is.
Not really, consider how would tumble motion mean the the end product ends up at a certain place? It's like playing Roulette or stopping an empty washing machine and expecting it to stop in the same place every time.
The roller wave pistons endeavour to push the whole of the mix over to the exhaust side where it's hotter, it isn't a fix, just a minor improvement. Has anyone ever done a proper scientific back to back test on them?
That aside, what happens is that raw fuel is left around the inlet valves, this is the cooler side of the port and that is the cause of det. Put some water in your mouth and try to blow it out in a mist, it will curl around and coat your lips, this is what wetflow testing or similar will show you.
Then you have to have a deep understanding of detonation and it raises the question; does it actually damage the areas which are the cause? I believe it does, but maybe not exclusively. This is why DI in petrol engines represent a massive step in so many important aspects of the engine.
The above observations are based on a 4 valve per cylinder motor.
I don't think so, but then again it's not like I have looked inside a running engine. I'm mostly just thinking out loud. Don't misread any excessive degree of confidence to my writings.
I have tried to read a lot of research on cycle-to-cycle variability. The new research uses large eddy simulations and camera instrumented test engines. The only problem is that almost all of the very latest stuff is about gasoline direct injection motors, but there is some port injected research as well.
I agree that there's a lot of variability between cycles, and by one Japanese study even the small intake and exhaust squish pads cut that down a lot. They also speed up the burn, which may not be desirable for a high-boost pump gas motor.
A number of recent articles (mostly French) show cycle to cycle variability in the flame travel for the standard four-valve head that burns towards the exhaust. This both with LES and video, they have a database of experiments now. All the cycles, both fast and slow, burn towards the exhaust.
There's also studies that measure the onset of the knock. For the standard four valve head with the spark plug at the roof like in normal production engines, all the knock events come from under the intake valve edges. When the standard plug is replaced with a very long experimental plug that has electrodes close to the piston, now all the knock events move to under the exhaust valves.
All this research points towards a large part of the tumble motion systematically and reliably persisting even near TDC, with the gas flowing from the intake side towards the exhaust side near the combustion chamber roof and from the exhaust side towards the intake side near the piston. I would post the diagrams from my phone, but this site doesn't know how to automatically resize attachment images so no photos of diagrams from the papers.
There's another study about tumble and piston dish shapes. The now-standard dish piston generates a stronger tumble than either flat top piston or a GDI dish piston. That makes sense, and I'd guess from that research that the roller wave piston also generates a strong tumble.
I don't have any obvious reasons to think that detonation only damages areas that are close to the point where the knock starts. You don't have any obvious reasons to put much weight on what I think!
Anyone with an internet connection can read those papers and instantly exceed my expertise on the area.
