ATK cylinder heads - good, bad or ugly?
Re: ATK cylinder heads - good, bad or ugly?
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
918-520-3480
www.wengines.com
Wow I'm not crazy. Referring to the profiler picture- Mine is shadowed just like that!! It's like the bolt holes need to be raised to center the port
On the Profiler head with the raised D ex port what is the height from the bolt C/L
to the top of the ex port?
Want to see if a 1-3/4" conventional header will work.
I believe the raised floor is intended as a anti reversion step to the header.
But wonder about the roof of the port relative to the header tube on the Profilers.
It is nice to now have a choice in ex port style with the ATK version.
A very nice cylinder head either way.
All I can tell you is my CNC exhaust port is much different than the as-cast version.
I started with a pro-port type casting.
I used a 1406 as a guide.
I guess when Pro-Filer says they are raised .250 they mean it! If you want a stock location, buy a ATK.
We were seeing a lot of issues with the Pro-Filer version on our end and exhaust port leaks. I cant tell you how many customers couldn't figure it out and got upset thinking something was wrong with the engine, send the engine back for warranty and it was blatantly obvious what the issue was Due to this and seeing another market for them we wanted a redesigned exhaust port in the stock location and have not had an issue since.
The other change we made was milling down the spring pockets and cutting a trough so the oil can drain back to the engine without restriction. We were seeing issues on the dyno and in the field with oil pooling up and burning, smoking out the breathers, etc...Overall its a very nice setup, the parts are equivalent to what you would find on Dart, Edelbrock, Brodix, Etc without paying the premium for upgraded parts.
ATK HIGH PERFORMANCE ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
CUSTOM BUILT STREET/STRIP & RACING ENGINES!
Drain Back Revisions
How are so many people having trouble with oil drain back and using oil through the guides with profiler heads? Mine have none of these mods and I've had zero issues. What causes these issues? I run a standard volume pump with the high pressure spring.
I'd just drill a little drain hole and let the springs sit in a pool of oil, as long as it did not reach the top of the guides
way back when we took the chevy steel shield cups from the top of the valvespring and turned them upside down with a small hole...
I bet 75%+ of all non drag racing customers don't know there headers are mismatched.Notalent wrote:We were seeing a lot of issues with the Pro-Filer version on our end and exhaust port leaks. I cant tell you how many customers couldn't figure it out and got upset thinking something was wrong with the engine, send the engine back for warranty and it was blatantly obvious what the issue was Due to this and seeing another market for them we wanted a redesigned exhaust port in the stock location and have not had an issue since
It took Posting here to get some positive confirmation. I emailed and talked to the "experts" and they didn't see it or didn't understand. I feel better but still upset my headers interfere with roof of the exhaust port. I tried at least 3 headers and non lined up with the profiler head. I know I wouldn't of bought them if the advertisement(or seller) would of stated raised ports requires unique headers to fit properly - or you need to buy the pro port CNC version to get a normal fitting exhaust port.
I'll stop beating a dead horse - thanks to all that posted their issues too.
If I had known about the ATK heads I would have bought them & had them ported.
Jim
- af2
You said the headers fit but the gasket didn't earlier?? Now this?mtrhead wrote:I bet 75%+ of all non drag racing customers don't know there headers are mismatched.Notalent wrote:We were seeing a lot of issues with the Pro-Filer version on our end and exhaust port leaks. I cant tell you how many customers couldn't figure it out and got upset thinking something was wrong with the engine, send the engine back for warranty and it was blatantly obvious what the issue was Due to this and seeing another market for them we wanted a redesigned exhaust port in the stock location and have not had an issue since
GURU is only a name.
Isn't every AFR head raised .250? What do they use for headers?
- af2
Trim the top of gasket and have a cold one on me... This is funny. NOT!
I had to use Fast Burn flanges & slot the holes & Track 1 gaskets & slot the holes, the flanges were for 1 3/4 pipes. 1 5/8 would have been to small.
Jim
