They wanted to keep the cam specs a secret so they covered the cam up. They were afraid that if you saw the lobes you might be able to figure out the specs. LOLcgarb wrote:The newspaper cam in there looks high tech too...lol.
There was a fad for running small journal cranks in large journal blocks for a while.BILL-C wrote:I'm noticing the same spacer shells we use to install a 283 main crank into a 350 main size block. What's up with that?
When the LS motors came out GM claimed the holes drilled above the mains did all kinds of wonderful things. I kept looking at the pictures and thinking that since the whole bottom was still open even with the fat main caps, how could it make any difference?plovett wrote:Wouldn't much smaller holes function just as well for pressure transfer?
dwilliams wrote:There was a fad for running small journal cranks in large journal blocks for a while.BILL-C wrote:I'm noticing the same spacer shells we use to install a 283 main crank into a 350 main size block. What's up with that?
the NASCAR deal also reduces the weight of the rotating assy parts.racear2865 wrote:dwilliams wrote:There was a fad for running small journal cranks in large journal blocks for a while.BILL-C wrote:I'm noticing the same spacer shells we use to install a 283 main crank into a 350 main size block. What's up with that?
Geez, this is not a fad. It is still performed everyday. Look at Nascar with Honda rod journals. $00 main SBC sized down to 350. Its called bearing speed. I do it every week in drag motors and some roundy motors.
reed
bet they drill straight thru from the timing gear area and then plug the front holes if necessary using a NTP plug.. I believe GM now casts the holes in the LS blocksbill jones wrote:-I'd like to see how you go about drilling those holes thru the main webs of the SBC engine---looks like it takes something more than normal---needs some out of the ordinary equipment.
it is the extended block below the crank centerline that adds to the windage problemec1 wrote:According to a GM dyno guy i know when they drilled the holes in the LS1 it was good for 15 HP on the dyno. I guess it's hard for the windage to get around the large main caps. Hence the reason they improved that method in the LS2 on up going with the block scallops around the outside of the main caps and the windows under the bores.
