Pro filer 290 vs Trick flow 280
80iowaBu
Post by 80iowaBu »
Getting ready to order heads for my 466 big block chevy build. And I'm torn between these two sets of heads. I have a wieand team g 4500 flange oval port intake, set of domed srp pistons. Factory forged crank, eagle I beam rods. Trying to make as much power as I possibly can. This engine will have a solid roller camshaft. This is for street/strip car. More along the lines of strip car with limited street driving. Either set of heads I end up with will be worked over. So if anyone has any experience with these two castings I'd like some input so I don't start off on the wrong foot.
user-17438
Re: Pro filer 290 vs Trick flow 280
Post by user-17438 »
I liked the trick flow better myself for a 496 I built for a customer, I got them bare no valve job. with some fluff work and a mid 260@.050 they made 700hp. pump gas
Profiler head is good also, depending on how high you want to make power. that will determine what head you need. please post more information. Edelbrock makes a great head also. as far as oval vs square.. I think its mostly marketing at that level.
mag2555
Post by mag2555 »
The trick flows may be 10 CCs smaller , but by there flow numbers they more a good amount more air in the all important .300" to .400" lift range.
If you get them and do not have a flow bench to guide your porting rework then I would not touch a thing about them!
Getting fat flow numbers down in that lift range is far more difficult then reworking the head for bigger high lift numbers!!!
David Vizard
Post by David Vizard »
I have tried both heads while researching my BBC book. I don't think you can go wrong with either brand of heads here but you had better have a good idea of how to port them.
DV
67 Nova
Post by 67 Nova »
I would also take a VERY GOOD look at the Flotek 290's from Chad Speier... Very Very nice castings, Chad can load them with his stuff for YOUR needs, and still be a bunch of $$$ savings. And since the $$$ savings, get Chad to work them and be about the same $$$ as the others with a semi custom head for your needs...
John
