First time out with new 412Reher Morrison looking for opinions
Arthur
Re: First time out with new 412Reher Morrison looking for opinions
Post by Arthur » Sun Apr 14, 2019 5:21 am
Steve.k wrote:
Sun Apr 14, 2019 12:48 am
Arthur wrote:
Sun Apr 14, 2019 12:39 am
VegaJohn wrote:
Sat Apr 13, 2019 10:09 pm
I’ve never heard of Reher Morrison building junk. They heads are CNC ported by them and the cam is spec’d By them also. I may have misquoted the figures slightly but the cam part number is a 410-110. The gearing will be too deep for spray I know that but perfect for N/A when you consider my 1.76 first gear. My results after switching from 4.88s to 5.67s also proved it. That advice was from Big Joe himself. With our bad air I would be more than happy with a 5.7. I don’t expect that even with a tunnel ram.
At your race weight 600 gets you 5.7 @ 660
Your setup is extremely inefficient
Facts are painfull for most
Enjoy
Explain in detail where he should go. Just remember he has no air where he's at.
He should find some -ain’t too hard
Details are not efficient going by the clock
Plenty of others that will tell him to buy this and that
Enjoy
Post by F-BIRD'88 » Sun Apr 14, 2019 6:49 am
Arthur: if his car was Racing at sea level it would make the 600 hp (Dyno SAE corrected )
He is not at sea level. Your N /A engine makes a lot less power at his elevation than at sea level.
when you correct for elevation it is being all it can be and should be.
Actual racing conditions matter.
tenxal
Post by tenxal » Sun Apr 14, 2019 8:40 am
VegaJohn: Neat car...keep doing what you're doing. I'd recommend working with a convertor company that's a known quantity. Dynamic Convertor is one company that I've had great luck with. http://www.dynamicconverters.com/converters.htm
P.S. It's not hard to tell the real racers from the keyboard racers. :wink:
Steve.k
Post by Steve.k » Sun Apr 14, 2019 10:04 am
Enjoy
Enjoy
Thats because hes at altitude. Every engine I've dynoed sees over a 100hp drop from dyno to track accounting for driveline and altitude losses. I bought a small block mustang from a guy in Columbus ohio that car typically ran 6.9 -7.0 in 1/8. When i brought it here it ran 7.4 -7.5. We have since widdled it down to 6.85 but took a fair bit of work.Johns engine when corrected is nearly 700hp (i get 685 corrected)so very close to rehers claim.
VegaJohn
Post by VegaJohn » Sun Apr 14, 2019 10:20 am
F-BIRD'88 wrote:
Sun Apr 14, 2019 4:32 am
I dispute your $(can) to $(us) cost difference.
The dollar exchange is 30%. Not 60%.
I was just being a smart ass. You are correct,but we are always on the shat end of the stick up here so we get cranky lol
VegaJohn
Post by VegaJohn » Sun Apr 14, 2019 10:26 am
“Find some air” hahaha that’s the best Perf tip I’ve ever received. If it was only that easy. When I have tried it on Q16 fuel it does really help out to the tune of nearly a tenth on the bad days. But I’m a low budget guy and that stuff is expensive. This season I’m trying to find a sponsor to help with fuel costs. In exchange their name will wheelie last fans on every pass 😬
VegaJohn
Post by VegaJohn » Sun Apr 14, 2019 10:32 am
Thank you to you guys who are here to lend some knowledge and help out. I know their will always be those other guys and I will just ignore it.
randy331
Post by randy331 » Sun Apr 14, 2019 2:14 pm
VegaJohn wrote:
Sat Apr 13, 2019 7:45 am
The cam is right around 286/296@50 .750/.720 lift.
I'd replace that.
Randy
CGT
Post by CGT » Sun Apr 14, 2019 3:22 pm
I'd replace that.
Randy
You cant make any power with the valves closed! :roll:
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
VegaJohn
Post by VegaJohn » Sun Apr 14, 2019 4:18 pm
I'd replace that.
Randy
Especially when Arthur won’t share his magic air lol
Arthur
Post by Arthur » Sun Apr 14, 2019 9:09 pm
Reality check Vegan
You should of specced a higher rated engine due to your elevation
You did not due to your short arms
This thread is about blood from a stone
Which is expected from a tight wad
Enjoy
VegaJohn
Post by VegaJohn » Sun Apr 14, 2019 9:18 pm
Reality check Vegan
Enjoy
[/quote
You were way funnier as a drunk in that 80s movie. Beat it, not everyone is rich or an a hole. You are one of the 2 and maybe both.
Arthur
Post by Arthur » Sun Apr 14, 2019 9:20 pm
Truth stings
Enjoy
Steve.k
Post by Steve.k » Sun Apr 14, 2019 9:23 pm
Id say arthur someone we know by sounds of it.lol.
Arthur
Post by Arthur » Sun Apr 14, 2019 9:26 pm
You going against your buddy?
Follow the money
Always leads to the truth
Enjoy
