Which Is Faster - 600hp@6200 or 600hp@7100
vortecpro
Post by vortecpro »
I'am going to ask the same question I asked on the Chevelle forum.
"Which engine is faster down a dragstrip and why"
A 427 that makes 600 HP @ 6200 RPM
A 427 that makes 600 HP @ 7100 RPM
user-17438
Re: Which Is Faster
Post by user-17438 »
More rpm is more gear.. more gear is torque multiplication. .
digger
Re: Which Is Faster
Post by digger »
if they had a cvt then basically the same but the lower rpm engine might have less losses in the transmission and more to the wheels but not much.
In reality you need to compare the hp curves not the peak of you want to get anywhere
JoePorting
Re: Which Is Faster
Post by JoePorting »
I would say the 427 that makes 600 hp at 6200 rpms because that suggests it might make 700 hp at 7100 rpms.
Joe Facciano
DCal
Re: Which Is Faster
Post by DCal »
RPM is wheel speed and wheel is MPH, look at Warren Johnson's record. In his heyday he consistently had the fastest car. NHRA has limited the rpm and now 210mph is considered fast, of course the rest of the combo has to be adjusted to work as a package.
vortecpro
Re: Which Is Faster
Post by vortecpro »
Theres two answers on here I like a lot =D> . Same exact curve except one is 900 RPM higher.
peejay
Re: Which Is Faster
Post by peejay »
Whichever one is geared appropriately to the powerband will have a better ET, but the MPH will probably be the same no matter what.
More likely, if the engines are the same displacement, they probably make about the same amount of torque, so they can't be "the same curve". I am going to assume that the higher revving engine sacrifices a little bit of peak torque for a softer yet longer powerband. So the higher revving one probably is putting down more average HP in each gear, assuming that the one with a lower RPM horsepower peak lays down early.
Power curves are not peak numbers, but you can infer a lot...
bigjoe1
Show Guest
Show Guest
Re: Which Is Faster
Post by bigjoe1 »
I like the higher RPM engine every time
JOE SHERMAN RACING
ptuomov
Re: Which Is Faster
Post by ptuomov »
vortecpro wrote:Theres two answers on here I like a lot =D> . Same exact curve except one is 900 RPM higher.
Shifted right by adding a constant factor to rpm or by multiplying rpm by a constant factor? In the latter case, I'd say I couldn't guess which would be faster. Equally fast up to my abilities.
Put Search Keywords Here
Geoff2
Re: Which Is Faster
Post by Geoff2 »
I suspect 600 hp @ 6200 will be faster. The engine making 600 hp@ 7100 will be making less hp @ 6200....
paulzig
Re: Which Is Faster
Post by paulzig »
Geoff2 wrote:I suspect 600 hp @ 6200 will be faster. The engine making 600 hp@ 7100 will be making less hp @ 6200....
But the 600HP@6200 makes less HP at 7100RPM ....
If you shift the 7100RPM engine at 7800 then it wont fall back to 6200RPM on the shift.. So does what it makes at 6200 have any real value?
user-612937456
Re: Which Is Faster
Post by user-612937456 »
The engine making more power at lower RPM has to be making more average torque. If the chassis is the same for both then whichever engine the chassis is set up for will work best. If you optimize the chassis for each engine, the lower RPM engine making the most average torque will be the fastest. Although the difference will be tiny. Assuming the lower RPM engine has more compression? Raising the peak power rpm, it will make more HP so there will be the faster of the two
BILL-C
Re: Which Is Faster
Post by BILL-C »
The higher rpm peak version 427 , when geared properly, will make car faster. More power cycles in the same distance, so more work gets done.
Carlquist Competition Engines
hoffman900
Re: Which Is Faster
Post by hoffman900 »
Higher rpm. Every time (assuming both versions are optiminly geared for their respective power bands).
KnightEngines
Re: Which Is Faster
Post by KnightEngines »
Whichever has gear & converter to keep the motor closest to peak hp rpm for the whole pass.
Or whichever makes more average hp in the range dictated by gear & converter.
Rpm makes no difference, but usually the motor that peaks at higher rpm will be easier to keep near peak hp.
