8.1 inch rod in stock block/stroke 350 and -----
David Vizard
Post by David Vizard » Sat Sep 23, 2017 1:42 pm
the top ring won't be coming out of the top of the block!
This is a teaser!
DV
Carnut1
Re: 8.1 inch rod in stock block/stroke 350 and -----
Post by Carnut1 » Sat Sep 23, 2017 1:51 pm
I am going to guess no rings involved. The rod looks like a stretched 70's vintage smallblock rod.
631-816-4911
9:00am - 9:00pm EST
David Vizard
Post by David Vizard » Sat Sep 23, 2017 1:54 pm
Carnut1 wrote:I am going to guess no rings involved. The rod looks like a stretched 70's vintage smallblock rod.
Charlie,
All the rings will be in the bores. You are right about the rods - 2 chopped 350 rods welded togeher.
DV
Carnut1
Post by Carnut1 » Sat Sep 23, 2017 1:57 pm
I hope that rod was x-rayed and heat treated after welding. Interesting experiment.
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 » Sat Sep 23, 2017 2:13 pm
I always liked the longer rods, I did a small journal 391 chevy with 6" eagle H beam rods. 3.825" stroke I think, made for a very short piston with the pin in the oil ring. I really don't see how that long a rod can be made to fit a 9" deck and a 3.48" stroke. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
peejay
Post by peejay » Sat Sep 23, 2017 2:15 pm
Hmm.... At first I was thinking grooved pin buttons, but now I am wondering if the wristpin tolerance was tight enough you could put the rings UNDER the pins. Or maybe just some grooves for O-rings, the piston and pin wouldn't get hot enough to affect some of the higher temperature O-ring material and there'd be no flow through the area so any gas there would be stagnant anyway.
pamotorman
Post by pamotorman » Sat Sep 23, 2017 2:25 pm
the advantage of the long rod is weight saving in the piston. the ratio is 2 to 1 for 1 gram of weight you add to the longer rod you save 2 grams in the shorter piston
BigBlocksOnTop2
Post by BigBlocksOnTop2 » Sat Sep 23, 2017 2:39 pm
I would not trust it as far as I could throw it. Going to be using a .25'' thick copper gasket?
Post by PackardV8 » Sat Sep 23, 2017 2:41 pm
Interesting math; check me here, but an 8.1" rod and 1.74" of stroke = 9.84"; can't stay under a 9.025" OEM SBC block deck, so that's already .815" out of the deck before we consider the piston and rings?
gnicholson
Post by gnicholson » Sat Sep 23, 2017 2:47 pm
I'm thinking it doesn't have a traditional wrist pin but rather some kind of captured ball and socket arrangement right under the Piston deck :mrgreen:maybe theres a hole in the piston deck and the pin goes on top. I think I've got it. the deck of the Piston splits with the top cap unbolting and reinstalled after the rod and pin are in place
David Vizard
Post by David Vizard » Sat Sep 23, 2017 3:00 pm
BigBlocksOnTop2 wrote:I would not trust it as far as I could throw it. Going to be using a .25'' thick copper gasket?
Trust me here but these rods will survive the peak rpm involved for at least 500 hours. Also no head gasket involved.
PRH
Post by PRH » Sat Sep 23, 2017 3:22 pm
Sure...... A stock "350".
But a 350 what?
Might be a 350ci twin cylinder engine that turns less than 2000rpm.
David Vizard
Post by David Vizard » Sat Sep 23, 2017 3:47 pm
PRH wrote:Sure...... A stock "350".
But a 350 what?
Good try PRH but no it is a 350 Chevy block 9.025 height.
DV
dwilliams
Post by dwilliams » Sat Sep 23, 2017 3:52 pm
I'd love to see some information about the welding job...
lefty o
Post by lefty o » Sat Sep 23, 2017 4:03 pm
ive no idea how you can squeeze that long a rod in a stock 350 block without talking something like a 9.5" block with about a 3" stroke crank, maybe even a shorter stroke, and just a big bore...idk. an 8.1" rod in a 9.025deck block dont leave much room for piston pin height nor any kind of stroke on the crank. #-o
