Power valve vacuum side halfways wet....
- Location: Los Angeles, in The People's republic of Kalifornia
Whenever I disassemble my Holley, I notice that the vacuum side of the power valve metering block gasket is wet. Is this normal? If it isn't new gasket or double up on them? They are the blue silicone reusable ones.
Re: Power valve vacuum side halfways wet....
The Blue ones are reusable, but so are the stock ones if you lay a film of wheel bearing grease or silicone grease on them.
Shouldn't be fuel on that side.
Bad PV, bad PV gasket, or warped body allowing cross channeling.
Bullock's Power Service, LLC
Plattsmouth, NE
Plattsmouth, NE
In regards to the fuel seen on that side, if your using a power valve plug many times they act as being too deep and bottom out on the center section of the Carb body and cocking the metering plate.
Look for signs of contact by the plug on the center section and correct for the excess thickness of the Carb body with a 3 second grinding session!
That is probably just from the gasoline vapor that is in the intake when the engine is running. After all that cavity behind the power valve is connected directly to the intake. It doesn't necessarily mean that there is anything wrong with the carburetor.
make sure the PV vacuum passage holes in the main body, gasket and base plate all line up. I never cared for holleys anti backfire valve in race engine base plate
How would vapor get in there if there's nothing sucking it up into that space, especially through a tiny hole, and it leaves a Horizontal wet line???DaveMcLain wrote: ↑Tue Oct 10, 2017 10:12 am That is probably just from the gasoline vapor that is in the intake when the engine is running. After all that cavity behind the power valve is connected directly to the intake. It doesn't necessarily mean that there is anything wrong with the carburetor.
No plug ,but I do use a plastic p/v gasket. Would that do it? I do get 15"HG at idle.mag2555 wrote: ↑Tue Oct 10, 2017 8:54 am In regards to the fuel seen on that side, if your using a power valve plug many times they act as being too deep and bottom out on the center section of the Carb body and cocking the metering plate.
When the engine is running and you open and close the throttle the pressure in the intake manifold as well as the pressure in that chamber behind the power valve changes. That's how liquid fuel can be drawn into that area. How would it leave a liquid line if the vacuum hole to the intake was actually open would be a better question.sc2dave wrote: ↑Tue Oct 10, 2017 8:02 pmHow would vapor get in there if there's nothing sucking it up into that space, especially through a tiny hole, and it leaves a Horizontal wet line???DaveMcLain wrote: ↑Tue Oct 10, 2017 10:12 am That is probably just from the gasoline vapor that is in the intake when the engine is running. After all that cavity behind the power valve is connected directly to the intake. It doesn't necessarily mean that there is anything wrong with the carburetor.
I also have the p/v blowout obstruction there also,so less chance of it getting in there.DaveMcLain wrote: ↑Wed Oct 11, 2017 7:35 amWhen the engine is running and you open and close the throttle the pressure in the intake manifold as well as the pressure in that chamber behind the power valve changes. That's how liquid fuel can be drawn into that area. How would it leave a liquid line if the vacuum hole to the intake was actually open would be a better question.sc2dave wrote: ↑Tue Oct 10, 2017 8:02 pmHow would vapor get in there if there's nothing sucking it up into that space, especially through a tiny hole, and it leaves a Horizontal wet line???DaveMcLain wrote: ↑Tue Oct 10, 2017 10:12 am That is probably just from the gasoline vapor that is in the intake when the engine is running. After all that cavity behind the power valve is connected directly to the intake. It doesn't necessarily mean that there is anything wrong with the carburetor.
I've seen a number of under-torqued PVs. Spec. is 40-50 in-lbs.
(Love these old 'similar topic' links.. )
I once had an issue with pv gaskets being too thick and just letting the m-block leak. So now I always clearance the mainbody cavity bolt boss a little.
