LS3 Carbed build
CGT
Re: LS3 Carbed build
Post by CGT » Mon Oct 29, 2018 10:24 am
Rowdy Yates wrote:
Mon Oct 29, 2018 12:17 am
Sounds familiar......... Save the money on bullshit testing waste of time and $
This engine is being built for testing things. Waste of time? Explain...Or are you saying testing cylinder head modifications or a waste? Or everything?
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
Rowdy Yates
Post by Rowdy Yates » Mon Oct 29, 2018 10:47 am
Testing the other heads besides the ones you have already. I've got Frankenstein stg1 Ls3 heads referred a few people.... 6.2 made 550rwhp with a LLSR Cam. 800 from a 418 that Flying did now for sale, he needs 900+ to be competitive.
CGT
Post by CGT » Mon Oct 29, 2018 10:52 am
Gotcha, get the Frankenstein's and be done......
Rowdy Yates
Post by Rowdy Yates » Mon Oct 29, 2018 11:25 am
There are other good Ls3 head porters....... They'll all be around the same ball park. Matching the CSA to the combination used is the main thing.
slo-svt
Post by slo-svt » Mon Oct 29, 2018 1:20 pm
Do you have real world experience with anything you have suggested or just read on the Internet?
"I believe in the scientific method and one should have a healthy skepticism of things in general. From a scientific standpoint, you always look at thing probabilistically and not definitively."
Elon Musk
Rowdy Yates
Post by Rowdy Yates » Mon Oct 29, 2018 2:07 pm
Can you read? I have a 408 with Ls3 heads and Ls7 heads. Facts are facts no matter where they come from.
Rowdy Yates
Post by Rowdy Yates » Mon Oct 29, 2018 2:20 pm
Same guy helped me set my heads up. EMC previous contest engine builder.
https://www.yellowbullet.com/forum/show ... ?t=1250106
CGT
Post by CGT » Mon Oct 29, 2018 2:31 pm
Rowdy, I don't see where your build is. Do you have some dyno data and or specs on yours?
slo-svt
Post by slo-svt » Mon Oct 29, 2018 2:45 pm
You could be asked the same question chief... He stated he purchased a gz vacuum pump just a couple posts prior to your first in this thread. You also haven't mentioned this 408 in this thread....
Elon Musk
slo-svt
Post by slo-svt » Mon Oct 29, 2018 2:46 pm
CGT wrote:
Mon Oct 22, 2018 11:18 am
As an update on the LS3. I purchased the Daytona sensors ignition, 2821 Super Victor 4500 flange, GZ vacuum pump, Whitener 1050. Also purchased the hollow stem LS9 exhaust valves that RW TECH mentioned to me. Its coming along...slowly but surely.
Elon Musk
Rowdy Yates
Post by Rowdy Yates » Mon Oct 29, 2018 9:33 pm
Got Everything just needs to be assembled. Ran into some legal stuff.... But to answer the question I can say for fact I've had guys who've had builds that were behind mine ...That were very similar helped somewhat with info... Go to the dyno and make what I said it would. Flying's 418 was a prime example...
Stated it would make 710 to 705 went to the dyno 708. Told him a solid roller with 8000 Rpm would make 800 went to the dyno 812. If you've looked over Ever build on Ls1tech & yellowbullet and I have. I can basically look at a combo, know the compression and Cam duration and intake used and get a very close ball park #. I love cylinder heads! Again I love cylinder heads.
Let me get on my home computer and give you the build info. Predicted to make 750 at around 7500 with the Ls3 top end and 800 -8200 with Ls7 heads that I've had Darin Morgan shrink the exhaust valve along with port work.
A_VAS
Post by A_VAS » Mon Oct 29, 2018 9:49 pm
facts found on the internet tend to be myths....
or was it myths posted on the internet after they get repeated long enough, become facts ?
I believe the truth will become apparent soon
too lazy to make power w/o boost
Rowdy Yates
Post by Rowdy Yates » Mon Oct 29, 2018 9:58 pm
408 ci LS Chevy
Block: LQ9, overbored, .030
Bore: 4.030 inches
Stroke: Eagle 4.00 inches # 434640006100
Displacement: 408 ci
Compression ratio: 11.8:1
Crank & rods: Eagle
Camshaft: 260-272 @ .050 730 lift both sides 113+5
Valve springs Pac 1238x springs
Lifters: Morel Bushed lifters #6177
Rocker arms: Comp Cams: Ultra Pro Magnum # 1676
Rocker ratio: 1:8/ 1:8
Ring pack: Total Seal gapless rings 1.2/1.2/3mm oil # MS4701 35
Pistons: JE asymmetrical forgings with lateral gas ports & coated skirts # 311979
(.004-inch piston-to-wall)
Main studs: ARP
Rods: Eagle 6.125-inch H-beam#CRS612503D
Main bearings: Clevite H
Rod bearings: Clevite HN
Cylinder heads: Frankenstein Racing heads LS3 stage 1 heads* 70.cc
Head bolts: ARP studs
Intake manifold: Edelbrock Super Vic that I ported ported
Intake flow: Also flowed by Chris Bennett @ SAM to verify 378 cfm at .750
Exhaust flow: 257 cfm at .750
Intake valve: Manley Hollow pro-flo 2.165 inches
Exhaust valve: Manley 1.600 inches
Head gaskets: Fel-Pro 1041 (.040 inch)
Throttle body: Accufab 4500 TB
Headers: Headman 1 7/8 step to 2 inch with 3-inch merge collector
Damper: ATI with 10 percent U/D
steel hub with aluminum shell
Water pump: Jegs 50 gpm electric
Oil pan: Moroso oil pan for 1990* S10
Oil pump: Ported Melling High oil pressure
Vacuum pump GZ super pro with Mandrel Pulley kit
Rowdy Yates
I guess your FAKE then A_VAS!
Ls7 heads milled to 61 cc's for about 13.2 compression
2.200 Titanium stock LS7 intake
1.550 Ferrea 24° exhaust
Flowed on 4.060 bore 28” TP
CCFM
Lift No. 1 No. 2
0.2000 111.2 165.2
0.3000 167.2 238.7
0.4000 191.3 300.6
0.5000 213.8 336.2
0.6000 219.9 360.1
0.7000 222.8 379.7
0.8000 225.0 370.0
Darin Morgan
Induction Research and Development
EFI Calibration
Reher Morrison Racing Engines
1120 Enterprise Place
Arlington Texas 76001
Phone 817-467-7171
Fax 817-468-3147
cell Funny!
http://www.rehermorrison.com
Cam# LS1, R80444-84455-115
270/284 @.050"
.444"/.455" Lobe Lift
.778"/.797" Net Valve Lift (after Lash)
115 LSA
Rowdy Yates
Post by Rowdy Yates » Mon Oct 29, 2018 10:11 pm
To: Chris Frank
Cc:
Subject: spec sheet missing for stage 1 ls3 heads
I spoke with you and I understand you are busy...I would also like the flow chart I am at 730 lift...Thanks for
the great work..I just need 2 have a reference for my own build library..
Int. 2.165
.200/159
.300/237
.400/282
.500/338
.600/368
.700/388
.750/390
Ex 1.590
.200/120
.300/190
.400/225
.500/242
.600/250
.700/255
.750/257
Kind Regards,
Chris Frank
FRANKenstein Racing Heads, LLC
328 N Broadway St. Ste. B
Joshua, TX 76058
Chris@Frankensteinracingheads.com
