LS3 Carbed build
202ci EH
Re: LS3 Carbed build
Post by 202ci EH » Fri Dec 07, 2018 6:34 pm
\:D/ Very nice.
Who's piston are you using? assuming its a shelf wiseco/diamond etc?
Not scared to turn the rpm's up with the stock rods? They seem to be fine cylinder pressure wise / compression, but tensile loading from piston speed? :-k
Nice build though, I like the whole less is more :-D
CGT
Post by CGT » Sat Dec 08, 2018 12:07 am
\:D/ Very nice.
Yes. It does scare me. But im fine with being a guinea pig on that.
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
CGT
Post by CGT » Sat Dec 08, 2018 2:33 pm
JE assymetrical shelf piston. 10cc dome
Olds455
Post by Olds455 » Sun Dec 09, 2018 1:33 am
CGT wrote:
Thu Nov 01, 2018 1:44 pm
Well. I agree with keeping things on track. Fortunately I have a killer cylinder head guy looking the heads over for hidden flowz. Hope to valve job them soon.
(Sn lives matter)
C h a d
Looking for hidden what? You don't make sense with that nonsense. I can't take you seriously nor anything you say when you act like that.
202ci EH
Post by 202ci EH » Sun Dec 09, 2018 3:29 pm
Thank's for that, nice looking slug.I had my eyes on the mahle dome pistons with the 1.0 x 1.0 x 2.0 ring pack until I realised they had a moly top ring.
I'm doing a similar build but with some Dart cathedrals, I've got my work cut out for me yet #-o
FC-Pilot
Post by FC-Pilot » Mon Dec 10, 2018 1:16 am
Not to derail the thread, but what is the issue with the moly top ring? Looking to discuss the technical reason why? Or are you saying it is a moly, and not a plasma-moly?
Paul
202ci EH
Post by 202ci EH » Mon Dec 10, 2018 3:05 am
No issues with the moly inlay, just that mine will see some nitrous in it's life and I wouldn't feel comfortable.
I like the gas nitride steel top that JE/SRP uses, they seem to last forever.
CGT
Post by CGT » Mon Dec 10, 2018 9:24 am
Hey 202. What are some of the details if your build?
FC-Pilot
Post by FC-Pilot » Mon Dec 10, 2018 1:02 pm
Thanks for the quick answer. Now, back to our regularly schedule program...
Paul
202ci EH
Post by 202ci EH » Tue Dec 11, 2018 4:41 am
It's a cheapy! :D Building it for my street car, trying to keep it basic and keep the $ down.
4.070 x 3.62
LS3 block, std crank. Likely end up with some compstar rods and JE or wiseco Domes
RHS/Dart cathedrals, started life as 225's but I'm about to go through them. Planning to run ls9 ex valves and turn ls3 hollow intakes down to 2.1.
Edel super Vic, Modded with a dominator flange.
4>2>1 header
Will be Hydraulic roller, std rockers with bushings, travel limited ls7 lifters, PSI Beehives, stock oil pump & timing gears with a c5r chain ~ just basic stuff, but the pudding is in the details I guess 8)
If it made 700 I'd be stoked, 650 would make me happy. Rpm's ~ as many as the valvetrain permits [-o<
CGT
Post by CGT » Tue Dec 11, 2018 9:15 am
4.070 x 3.62
4>2>1 header
That sounds cool.....and familiar. Im doing travel limited stock lifters also. How big are the heads now? Sizes, csa etc? Valvetrain is my biggest worry on mine.
3pedals
Post by 3pedals » Tue Dec 11, 2018 11:52 am
How much plunger travel are you guys leaving when you shim the lifters?
CGT
Post by CGT » Tue Dec 11, 2018 12:19 pm
Mine will have about half taken out initially. Leaving
.100 or a little less. I may take more out later but didnt wanna get too crazy while the valvetrain is still non adjustable.
3pedals
Post by 3pedals » Tue Dec 11, 2018 12:30 pm
Sounds reasonable,
where do you plan to set the assembled "plunger height"? Right In the middle of your travel?
CGT
Post by CGT » Tue Dec 11, 2018 12:36 pm
Sounds reasonable,
Most likely. I will probably base that decision on just how consistent one is to another. Im not wanting to buy 5 sets of pushrods. Buy yeah. Ill probably shoot for .050 or deeper to account for growth.
