LS3 Carbed build
CGT
Re: LS3 Carbed build
Post by CGT » Mon Jun 10, 2019 9:28 am
202ci EH wrote:
Mon Jun 10, 2019 12:17 am
Still plodding along? Have you got a deadline?
Finally finished my heads/intake (yes it does exist!)
Happy enough with how they turned out, intake gets a little choppy after .700 lift, like when the valve comes out of the chamber. Exhaust is quiet!
2.7 MCSA intake, 1.44" MCSA ex.
3.6" at the runner opening on the center runners and 3.8" outside. Manifold drops the flow #'s 2-7 cfm 😀
Photos too big to host here, let me know if the link is no good.
https://imgur.com/gallery/qlZjeDK
I don't have a deadline, but I'm not far off from being finished really. Sounds like you've been busy on yours. What valve job did you end up with on yours?
Mark Twain
Golf is a good walk spoiled.
Mark Twain
202ci EH
Post by 202ci EH » Mon Jun 10, 2019 9:50 am
👍 Cool no rush then.
I would have done a 50* seat but It's a streetcar, that and the ls3 hollows are too thin to get a seat.
37°-45°-63°-75° intake and just a 37°-45°-radius exhaust.
Cheers steve, Yep that's my work. Try to do as much myself as possible.
CGT
Post by CGT » Mon Jun 10, 2019 10:14 am
Well, it is no rush. But I've been working on it a lot. And its starting to add up. I would say I'll have it wrapped up in the next week or two. BTW, my heads get noisy through that area as well.
Mark Twain
Mark Twain
steve316
Post by steve316 » Mon Jun 10, 2019 11:17 am
Chad does your ports quiet down when you flow with manifold?
CGT
Post by CGT » Mon Jun 10, 2019 11:50 am
* does your ports quiet down when you flow with manifold?
Mine didn't.
Mark Twain
Mark Twain
202ci EH
Post by 202ci EH » Mon Jun 10, 2019 8:34 pm
Mine neither, though its hard to hold the intake on in alignment with the intake boly arrangement.
Rowdy Yates
Post by Rowdy Yates » Sat Jun 15, 2019 4:44 am
Zach Nelson winner of the EMC with the NOS ls is putting together, my 408 with Chris Frank factory ported Ls3 heads shooting for as much compression as we can get with milled heads and JE asymmetric flat tops 13.2+ & e85. Looking 4 a number with a street engine.
CGT
Post by CGT » Thu Aug 08, 2019 12:00 pm
As an update,the LS dyno project is all but finished and ready for its first dyno session..
I will most likely wait until summer passes, but I'm not positive. I think their is going to be a lot to learn from this one...…
I am running the Daytona Sensors ignition and harness. The harness is undergoing some alterations by a friend currently. 202..how's your project coming along?
Mark Twain
Mark Twain
GARY C
Post by GARY C » Thu Aug 08, 2019 12:41 pm
That thing is so cool!
Interesting build for sure I think it will do good.
GARY C
Post by GARY C » Fri Aug 09, 2019 9:36 pm
Did you stay Hyd Roller?
Have you found the need to make any changes from your original goal?
202ci EH
Post by 202ci EH » Fri Aug 09, 2019 10:01 pm
Neat looking package CGT 👍 Tall covers... Did you end up using a roller tipped rocker to get some more lift? Might have missed it, are you using generic Delphi/Delco/Elgin ls7 lifters?
Mine is finished up like yours, should be in the car running & driving in october. I'm having trouble fathoming $1100 for a basic 4500 throttle body though.
CGT
Post by CGT » Sat Aug 10, 2019 8:48 am
No. Stock rockers with Smith Bros. trunnion bushing kit. I ended up having my cam reground,,slower intake lobe and changed the exhaust lobe some as well. It is now 262-276 111 .680 .660.
Yeah stock Delco lifters, travel limited somewhat.
As someone that plays with old engines and newer stuff the prices of some things for the newer stuff is just ridiculous. The people that just began playing with engines with the newer stuff like LS, coyote ect...don't seem to see how outrageous some of the stuff is. They have no reference point from playing with old small and big Chevies and Fords. They tend to not blink an eye.
There is a LS or metric tax on some of these parts lol....although to be fair some of it is pretty affordable as well. ARP comes to mind. In my opinion they are flat out price gouging on some of their fasteners for the late model engines. How is a head stud kit for a SBC 125.00 but head stud kits for a LS start out at 425.00. 34 bolts in the SBC kit, 30 in the LS kit and 10 of those 30 are barely even bolts lol. I have let ARP know my feelings on this. :D
You decide not to dyno?
Mark Twain
Mark Twain
Elroy
Post by Elroy » Fri Aug 30, 2019 10:49 am
Got redirected here from a link someone posted elsewhere on here////OP,,,,,do you have a goal you are trying to reach for this engine? or did I miss that
CGT
Post by CGT » Fri Sep 06, 2019 11:04 am
I have no concrete goals at all really. I will just dyno it, try to learn from that, make changes, dyno. Its just unfortunately what you have to do when you don't already know everything :lol: .
I have a feeling I'm going to be up against some hydraulic lifter limits initially. But If I keep at it I could ultimately see 2hp/ci coming out of it down the road. That will require a solid roller and some development.
Mark Twain
Mark Twain
Orr89rocz
Post by Orr89rocz » Fri Sep 06, 2019 12:41 pm
Believe i seen a 416 stroked ls3 with ported ls3 heads make 812 hp with cid intake. Solid roller 7800 rpm
