Re: LS3 Carbed build
Posted: Thu Oct 24, 2019 2:46 pm
Home of Racing's Best and Brightest
Considering the stock cam pulls an LS3 close to that 6000RPM, you might have a hard time trying to make it RPM a lot less than what it is, so its a funny thing most of the time you struggle to go up in RPM not downrandy331 wrote: ↑Thu Oct 24, 2019 9:16 amit would take an extremely small cam to get Chad's 378 to peak at 6000-6200 rpm. I did a 408 ls with ported cathedral port heads, 2.02"/1.56" valves, 243/258/110 cam with .625" lift. sv intake, 4150 carb. It made peak HP at 6000-6200 rpm. The induction trac is the number one thing that determines where an engine makes peak at.
Randy
Didnt read thru the whole thread, just checked out page 1, is it still alky or gas, those csa's would make more sense if its still alcohol, its a little monster
What made you go that big for that cube and rpm with a carb
It really wasnt a clean sheet deal. Original goal was to see what could be done using as many stock parts as possible. I had a 6.2 ls3 core. The heads are bigger than this stock. They have been epoxied down some and will probably get epoxied up more and the intake manifold could use some also.
I can respect that, nice jobCGT wrote: ↑Thu Oct 24, 2019 10:19 pmIt really wasnt a clean sheet deal. Original goal was to see what could be done using as many stock parts as possible. I had a 6.2 ls3 core. The heads are bigger than this stock. They have been epoxied down some and will probably get epoxied up more and the intake manifold could use some also.
Stock valves have been turned down smaller, stock crank, rods, valves, rockers, lifters...i built it just for dyno testing so it may end up with a solid roller, better connecting rods , crank and more rpm.....more epoxy, or more stroke to bring the rpm range down...not sure yet
One apparent weirdness is that with a wet sump, the gauge reading psi will drop by 1/2 the "Hg. of pan vacuum, however the operating pressure differential between the pan and bearings will remain the same. In other words, if you enclosed the gauge in a sealed plexi box plumbed to the pan, the gauge would then not be affected by pan vacuum.
True, sounds more like CGT's seeing a windage or cavitation problem thoughMadBill wrote: ↑Thu Oct 31, 2019 9:16 pmOne apparent weirdness is that with a wet sump, the gauge reading psi will drop by 1/2 the "Hg. of pan vacuum, however the operating pressure differential between the pan and bearings will remain the same. In other words, if you enclosed the gauge in a sealed plexi box plumbed to the pan, the gauge would then not be affected by pan vacuum.
MadBill wrote: ↑Thu Oct 31, 2019 9:16 pm One apparent weirdness is that with a wet sump, the gauge reading psi will drop by 1/2 the "Hg. of pan vacuum, however the operating pressure differential between the pan and bearings will remain the same. In other words, if you enclosed the gauge in a sealed plexi box plumbed to the pan, the gauge would then not be affected by pan vacuum.
Exactly
Well it sounds flawless, as far as how it looks not sure. 30 or so dyno pulls...didn't pull the valve covers, still haven't I made a couple pulls to 7700 which inherently gets passed up by a bit and everything sounds real nice up there.
No. The cam I ordered this week is 4 degrees bigger on each side, spread the LSA a couple degrees, and used a slightly more aggressive exhaust lobe. So...bottom line, once I finally go solid roller I will have some weird-ass one-off hydraulic rollers laying around that will be good for nothing else. They don't really have enough lobe lift to be reground into good solid rollers without getting into the base circle too hard , and too much lobe lift for most street stuff.
Hard headedness . I work at a fairly large Chevy dealer, been in the business for a long time. I think I've seen 1...maybe 2 of these chain guides laying in the bottom of the oil pan. They were on very high mileage, ill maintained stuff. I'm not saying they don't or haven't failed outside of that.
I think it'd be interesting to do some oil pressure testing on a hyd roller set up like this one. One with some rpm and some lift.CGT wrote: ↑Fri Nov 01, 2019 10:04 am I think a solid roller for this engine would look quite a bit different than this hydraulic. To get a hydraulic roller somewhat happy in a deal like this, it seems you have to accept some penalties...excessive seat duration and much slower lobe speed or just a couple this engine has for sure, but I'm learning as I go.
