LS3 Carbed build
steve316
Re: LS3 Carbed build
Post by steve316 »
Chad do you know how much less this ls weight is than a aluminum head cast block first generation SBC. Thanks in advance Steve
CGT
Post by CGT »
steve316 wrote: Sat Nov 09, 2019 8:34 am Chad do you know how much less this ls weight is than a aluminum head cast block first generation SBC. Thanks in advance Steve
This engine should be right about 400lbs
Elroy
Post by Elroy »
Any updates on this?
CGT
Post by CGT »
Elroy wrote: Sun Nov 10, 2019 8:34 pm Any updates on this?
My goal is to have it back on the dyno in November, although I am currently at the mercy of a couple of suppliers.. along with a little fab work to the oil pickup tube.
bobmc
Post by bobmc »
did you end up using dowel shift?
CGT
Post by CGT »
bobmc wrote: Mon Nov 11, 2019 7:50 pm did you end up using dowel shift?
Yes
CGT
Post by CGT »
To anyone interested. I'm wrapping up some changes on this LS3 (oiling), and will be back on the dyno hopefully before the first of the year for more testing....fresh vacuum pump and oil pump. I plan on doing some cam position tests with my current cam, trying my timing curve built from last sessions data, doing a cam swap on the dyno along with ICL tests on it, maybe some oil weight testing, and possibly revisit the bigger carb thing, I couldn't really complete the carb testing last time because of lack of main jets to get the bigger carbs tuned up right.
Elroy
Post by Elroy »
How did I miss this///a dyno thread my favorite//have you used this dyno before??
CGT
Post by CGT »
Elroy wrote: Wed Nov 27, 2019 11:55 am How did I miss this///a dyno thread my favorite//have you used this dyno before??
Many times
randy331
Post by randy331 »
Did you get the intake ground out to fit the spacer for the bigger carb ?
Randy
CGT
Post by CGT »
randy331 wrote: Wed Nov 27, 2019 2:31 pm Did you get the intake ground out to fit the spacer for the bigger carb ?
No, just the open adapter spacer I told you about, matched to the plenum then tapered out to the larger throttle bores. I need to see some evidence of the big carb being better before I get after the manifold too hard.
rewguy
Post by rewguy »
Im sorry to ask.....but Ive searched....and somehow overlooked....what the compression, ring pack, and a few details like that were on your build CGT....? Could you write a very brief rundown? Its easy to get lost in 21 pages, lol.
Thankyou sir!!
CGT
Post by CGT »
rewguy wrote: Wed Nov 27, 2019 5:08 pm Im sorry to ask.....but Ive searched....and somehow overlooked....what the compression, ring pack, and a few details like that were on your build CGT....? Could you write a very brief rundown? Its easy to get lost in 21 pages, lol.
Thankyou sir!!
LS3 .005 over 4.070 x 3.622
C12 VP fuel, non oxy
14:1 compression
Stock crank, rods, rockers, lifters, block, heads, valves, pan, pickup, tensioner etc.
JE Assy forging 1.2 1.5 3.0 rings
CID 4.0 manifold
1050 Carb/Mark Whitener
Bullet Hydraulic cam
3/8 .080 pushrods
PSI beehives
Some epoxy work in heads. A lot of help and advice from Randy331 in the cylinder head department.
2.125 Intake 1.59 exhaust
There are quite a few details left out im sure, yould just have to read through in your leisure. Some I may have not even thought to post. The heads are offset doweled... just giving you some random details off the top of my head. If you have any specific questions ask away...
My original goal was to see what could be done using as many stock parts as possible....its making good steam(i think) now and im gonna keep trying to find more.
GARY C
Post by GARY C »
CGT wrote: Wed Nov 27, 2019 10:25 pm
Thankyou sir!!
14:1 compression
CID 4.0 manifold
3/8 .080 pushrods
PSI beehives
Should I say what I am thinking or does this page speak for itself? viewtopic.php?f=1&t=51466&start=180
randy331
Post by randy331 »
You going to try some pulls to 8000 rpm ? 8200 rpm ?
Randy
