Who is that guy? What's his name? I've seen that passed around the internet for a decade or more and still don't know of anyone who actually knows who "motoman" is.GRTfast wrote: ↑Fri Aug 23, 2019 6:54 am http://www.mototuneusa.com/break_in_secrets.htm
This guy has put a lot of time and testing into his method. A few AMA supersport and superbike engine builders I knew back in the day used it with success. The main idea is to build a lot of cylinder pressure as soon as possible.
A question for PROFESSIONAL engine builders
Re: A question for PROFESSIONAL engine builders
- BigBlockMopar
- Momentary Specialist
I'm not a pro either, I vary it between 3 and 4K with a load...once the oil is about 200 ,I check timing again , change the filter and if the fuel is good I let it rip.
Different sequence for ft cams
He is right about giving it the throttle early on..GRTfast wrote: ↑Fri Aug 23, 2019 6:54 am http://www.mototuneusa.com/break_in_secrets.htm
I disagree with him on the part about all cylinders are honed very fine now,, not true
Most rings I use lately are very narrow and small radial dimensions, 1mm or less,, and low or ultra low 2mm oil. Similar to bikes
They require a fairly rough final hone.. CP specifically says they will not seat with a fine hone... I don't have the specs right now but I will post a pic. It's surprising how rough they want it
I think he’s talking specifically about bike engines. Not sure though. I’ll defer to your experience, I’m sure you have more.gmrocket wrote: ↑Fri Aug 23, 2019 6:44 pmHe is right about giving it the throttle early on..GRTfast wrote: ↑Fri Aug 23, 2019 6:54 am http://www.mototuneusa.com/break_in_secrets.htm
Could be, he mentions the different types of bike liners but not cast iron.GRTfast wrote: ↑Fri Aug 23, 2019 8:27 pmI think he’s talking specifically about bike engines. Not sure though. I’ll defer to your experience, I’m sure you have more.gmrocket wrote: ↑Fri Aug 23, 2019 6:44 pmHe is right about giving it the throttle early on..GRTfast wrote: ↑Fri Aug 23, 2019 6:54 am http://www.mototuneusa.com/break_in_secrets.htm
I can remember in the early 1970's when my father put me in a racing go-kart and we would put a NEW McCullogh <(may not be spelled correct) 99cc 2 cycle engine on the kart he would have me go out and WOT to slowing down over and over for about 2-3 minutes and the goal was to cause the most possible cylinder pressure as GRTfast has wrote. Mark H.
