Do any of the shops here do lifter refacing?
I have a set of lifters that are virtually new but need to be refaced to use on a new camshaft. Do any of you guys do this?
Thanks.
Thanks.
Re: Do any of the shops here do lifter refacing?
I've had these guys machine lifters for me. Great, fast service.
https://mizpahprecision.com
I've done some biz with Charles @ Camcraft... and thanks Dave for that info. I was looking thru my hard drive since I have that shop info saved somewhere.
I know Egge does and does Costa Mesa R&D in CA.
Thanks to all...
Thanks to all...
I believe that the place I used....yes, great price and service...machinedave wrote: ↑Thu Apr 19, 2018 9:44 pm I've had these guys machine lifters for me. Great, fast service.
How long has this place been there? 60 miles down the road from me, the town has a bar, gas station, & post office, population 54.machinedave wrote: ↑Thu Apr 19, 2018 9:44 pm I've had these guys machine lifters for me. Great, fast service.
Jim
We do them, but mostly for our own use. If you can't find anyone else, PM me.
Thanks Jack...
I'm not sure. They are probably 4 hours north of me. I've never actually been there. I just mail them my lifters.77cruiser wrote: ↑Fri Apr 20, 2018 10:39 amHow long has this place been there? 60 miles down the road from me, the town has a bar, gas station, & post office, population 54.machinedave wrote: ↑Thu Apr 19, 2018 9:44 pm I've had these guys machine lifters for me. Great, fast service.
Good link to have.machinedave wrote: ↑Thu Apr 19, 2018 9:44 pm I've had these guys machine lifters for me. Great, fast service.
Back in the day we just used a sheet of 600 grit on a glass flat surface and ran them in a figure 8 pattern while turning the lifter, new cam old lifter, old cam new lifter, never lost a lobe but I don't know if that would work with modern aggressive lobes.
For the guys that do lifter refacing, do they grind a true radius?
My KO Lee made valve refacer has a lifter attachment but it surfaces at an angle with a slight peak in the center.
Monty Frerichs
B&M Machine
B&M Machine
Quality Performance Products, Spencer WI. 715-659-5152
i polished them the same way but i put a piece of foam rubber under the emery paper so the polishing followed the radius on the lifter base. the best way is in a lathe and hold the emery in your handGARY C wrote: ↑Fri Apr 20, 2018 1:13 pmGood link to have.machinedave wrote: ↑Thu Apr 19, 2018 9:44 pm I've had these guys machine lifters for me. Great, fast service.
I agree but now that I have a lathe I don't have any flat tappet projects.pamotorman wrote: ↑Fri Apr 20, 2018 3:27 pmi polished them the same way but i put a piece of foam rubber under the emery paper so the polishing followed the radius on the lifter base. the best way is in a lathe and hold the emery in your handGARY C wrote: ↑Fri Apr 20, 2018 1:13 pmGood link to have.machinedave wrote: ↑Thu Apr 19, 2018 9:44 pm I've had these guys machine lifters for me. Great, fast service.
One hour west of me...
