Rapidly moving vacuum gauge at idle - smooth above 1k
Firedome8
Re: Rapidly moving vacuum gauge at idle - smooth above 1k
Post by Firedome8 » Sun May 20, 2018 9:19 am
A leak down test is a good next step. You can inrich the mixture at idle with propane to see if the engine wants more fuel. Just thinking.
BigBlockMopar
Momentary Specialist
Post by BigBlockMopar » Sun May 20, 2018 9:40 am
Just did a compressiontest with a screw in type gauge.
All cylinders were between 208 - 210 psi, except cyl. 6, which had ‘only’ 195-198 psi.
Engine temp was around 135F, carb at WOT.
I did 2 tests in a row, one bank at a time from front to back: 1357-2468-1357-2468.
First round I got numbers just above 200-205 psi, second round I got the numbers mentioned above.
So my focus is on cyl. 6.
