Rapidly moving vacuum gauge at idle - smooth above 1k
Re: Rapidly moving vacuum gauge at idle - smooth above 1k
A leak down test is a good next step. You can inrich the mixture at idle with propane to see if the engine wants more fuel. Just thinking.
A good test is worth a thousand opinions.
Smokey
Smokey
- BigBlockMopar
- Momentary Specialist
Just did a compressiontest with a screw in type gauge.
All cylinders were between 208 - 210 psi, except cyl. 6, which had ‘only’ 195-198 psi.
Engine temp was around 135F, carb at WOT.
I did 2 tests in a row, one bank at a time from front to back: 1357-2468-1357-2468.
First round I got numbers just above 200-205 psi, second round I got the numbers mentioned above.
So my focus is on cyl. 6.
Hello Big block mopar... did you mange to find out the problem. Thankyou, Inhave the same problem as jou have
Does it have any valve train noises?
Smokey
Smokey
- BigBlockMopar
Older topic, but,
no obvious valvetrain noise present, but I can tell during driving when valve-lash is getting upto around .010".
I currently have the engine opened-up and will replace the iron heads for a pair of aluminium heads and will do a cam change as well. Going to a hydr. roller.
