350 TBI tows 5000/6000lbs
donforeman
Re: 350 TBI tows 5000/6000lbs
Post by donforeman » Sat Feb 09, 2019 6:38 pm
Stock manifolds with the air boss plugs milled out. Even though the air bosses were undrilled they blocked off a lot of the upper port. One is OEM the other is Dorman. Dorman has bigger passages. I did a budget 409 exhaust, no cat but a big and quiet Jones SS muffler. I used pie cuts out of straight 409 tube from Summit, mostly welding practice and I need more of that.
cardo0
Post by cardo0 » Sat Feb 09, 2019 6:44 pm
That's a lot of good useful info and thx for sharing. What I see is your making 30ft-lbs more torque at over a 1000rpm less than your previous peak torque. But now your fighting knock and the cheapest cure for that is make it richer. Gonna need a wideband for that but I imagine a wet flow system would like 12.something for A/F though your in the high 12's already. And you can still run the engine way richer but it uses a lot more fuel and power begins to taper off. Won't hurt to try though.
Old School
Post by Old School » Sat Feb 09, 2019 10:09 pm
How does your fuel economy compare before and after?
donforeman
Post by donforeman » Sat Feb 09, 2019 10:42 pm
I cant really say mileage as most of my road trips for the last few weeks have included a lot of WOT to get readings in the different data cells, that really is not good for mileage. It took a lot of work to get the fuel table close. Its very close now but I think there is a little more left. There are some areas part throttle where the vacuum is actually really good, better than the stock combo. So I think that should mean better mileage when tuned properly and I am not towing. I have a wideband on both the dyno and on the van. The one on the van just logs data so you can compare it to the block learn in the gm ecm. I will say that it would be very easy to mess up the mileage following some of the advice on Power Enrichment given on the internet. Some of the stuff like AE was increased about 15% just on the advice of some forum members past experience. Once the tune is a little closer I will gradually try to take some of those changes out and see what happens. The software is not perfect, there are glitches and obvious mistakes that makes some readings not make sense. I figure the theory of making as few changes as possible is the best as some stuff is just a mystery that no one can explain. In $OD in tunerpro and some android data loggers, any retard of the total timing will log 23000 degrees advance or more. I burned a -5 chip to test with fixed timing and my OTC scan tool reads -9 degrees which is a lot closer than 23000! There are some very smart people that have tried to help me out, one use to work in the electronic department for GM. He was the one that said even the aftermarket scan tools like OTC have mistakes in data as GM never released the code to the public. So its a wild guess working in reverse. He said he had checked some of the transmission pressures against known good code he had and said changing some of those could result in the code being corrupt at times. So needless to say I did not touch any trans pressure settings on the chip.
gmc406
Post by gmc406 » Sun Feb 10, 2019 10:43 am
Talk to this guy
http://westersgarage.eidnet.ca/index2.html
His name is Lyndon. He may help you for the most part, but like any good tuner......I don’t think he’ll give away secrets.
He also tuned my 89 Camaro with a 420sbc that’s run off a TBI computer. It’s a lot of fun on the street, and runs perfect.
donforeman
Post by donforeman » Sun Feb 10, 2019 11:55 am
Thanks for the advice, its been a learning curve! I really don't want to bother anyone that doesn't volunteer information. I use to have a repair shop and it use to bug me people calling on the phone asking to borrow manuals, tools etc. So I will not do that to anyone else uninvited. I am not stuck yet, it's a process. The fuel map is pretty good so far. Verifiable with the wideband data. So time to switch gears and look at the spark timing. I tried to short cut it by using the 1995 LT spark table as that was recommended, I took it back out because of spark retard in a few areas and use the base vortec timing table for a late 90s vortec truck that has no retard anywhere in testing. Somewhere in between is probably the best compromise, but its snowing outside so I am not dragging out the chassis dyno today.
In $OD in TunerPro there is a a lot of files put together by mostly free labor and some files don't play well with others, even though to the new person, there is no real info on this. The A217 adx file does not account for any initial advance if its set. There is an easy way to add the initial advance (if any) into the data log file (adx), but it has to be done manually. While the 251 xdf (the one that converts what you type in to change the chip) does try to account for that, even though its not done in the file. That's the first stage. Once you get to that point, The logged data still will not exactly match the timing table. I think a few things could be happening. Either mistakes in the code that interprets what the computer is seeing. That is most likely! It also looks like on fast decel, the data is just too slow. What may start at one cell, ends up recorded in another as the rpm rapidly drops from WOT. I am not sure on the last one, but I think something like this may be going on. I try to remember to do throttle movements slowly as the logger seems to record more accurately.
In the TBI computers there is a field defined as spark latency correction. That's what I want to look at next. Different ignition modules require different settings in order for the computer to get close to what it's programmed spark wise. I guess age and other factors can change that requirement too. So the third gen camaro site has a few threads on how to check that and that's the plan. It really has been a struggle to find the nuggets of info, compared to the wrong info that gets parroted so often.
One big tip I got that may help others is the tbi computers have a idle spark over speed and under speed advance/retard tables at least on the 94/95 years. When I put in mild roller cam in the timing would be constantly advancing and retarding by a lot even just sitting there in neutral. Neutering those table advance and retard numbers when the idle was fairly close to the ideal speed, even with my baby cam, helped. I did leave some timing adjustment when the speed was greatly out of whack. Now the idle speed is stable, like stock, and the timing is not bouncing up and down like a yo yo on the data logger. That, raising the hot idle speed in gear to 600 rpm and fuel mixture adjustments where all I did to get a factory idle again. Larger cams will probably require more work, but for my small one it was done in less than 15 minutes of changes.
levisnteeshirt
Post by levisnteeshirt » Thu Mar 07, 2019 9:48 am
the factory pistons have a 1.540 ch ,, so that's gonna be a huge quench ,,, I don't have the heart to mess with my truck anymore knowing that ,, until it gets an engine with all the slop taken out
levisnteeshirt
Post by levisnteeshirt » Thu Mar 07, 2019 12:04 pm
randy331 wrote:
Tue Nov 13, 2018 6:50 pm
levisnteeshirt wrote:
Tue Nov 13, 2018 5:11 pm
i wonder if a pontiac type , 30 degree seat would help in a towing SBC
:lol: :lol:
Randy
talking about low lift flow , low rpm stuff
donforeman
Post by donforeman » Sat Mar 09, 2019 3:30 pm
I measured the deck height in a few places with the heads off. No great, not horrible for a stock short block. Shim gaskets would have been better but I didn't want to mess with any chance of coolant leaks. From what I hear the vortec ring package is better too. It's all how far you want to go. With 109000 on the short block I am very happy to let it be and work on that part in another 100k when its in worse shape. I haven't messed with much since the last post, I just drive it. It pulls good and seems to get the same mileage as stock. I am sure refining the timing and fuel tables more will help a little bit. The biggest thing I am upset about is the new jegs heads again, on top of everything else the guide seals that came on the new heads are leaking. I am getting a pretty good puff of blue smoke on deceleration when on the dyno.
levisnteeshirt
Post by levisnteeshirt » Sun Mar 10, 2019 7:32 pm
could be from a sharp deacceleration at full load , ,, that's a huge amount of vacuum being pulled , I wouldn't sweat it myself ,, especially for a tow vehicle ,,, unless it continues to get worse ,,, come off the fuel easy and see if it does it ,,,
Newold1
Post by Newold1 » Mon Mar 11, 2019 4:18 pm
Man those JEGS made in the USA Vortec heads are really weak. You can do a seal change on the engine in the van but is a great deal of extra work. Did you happen to check valve guide to valve stem clearance before assembling the heads? The fact they used liners in supposedly new heads blows me away and I hope the valve stem to guide clearances are not opened up and big as that won't go away. You might also want to remove the throttle body and with a flexible stem scope look down the ports near the head/manifold junctions and make sure the engine is not pulling oil from the valley on decel. Its not a big problem to fix but it can use a fair amount of oil especially on decel.
You've accomplished a lot on your redo here on the van and I hope you end up with some satisfactory improvement and the little glitches disappear for you. Let us know how things end up and if the towing is improved and a better driving experience. :)
donforeman
Post by donforeman » Mon Mar 11, 2019 7:36 pm
The heads were supposed to have bronze guide liners and be made in the USA, what I got was a cruddy pair of promax heads. Neither one had a liner when I looked again, just cast iron and fairly loose. They sent me a replacement head and the replacement was even worse, but by then I just wanted the van back on the road. They wouldn't take them back after I had painted and installed the one. They said they switched suppliers and never updated the description. After I harped on them several times they finally took the part about bronze guides off. At first they just said they would take the suppliers word that they had them. The casting is the same china made casting you find on ebay. I can swap out the seals in the van it's just a real pain. I took them both apart and got a new spring package to allow for proper clearance. The springs were stiffer than the springs that came stock by a bit.
The chassis dyno season is coming in a week or two and I need the van to tow it so I think I will just use it for six months or so as is and hope for the best. Most of my towing is less than 20 miles with a few out of town trips. It only really does the smoke on decel when I do a WOT run on the dyno then just let off the throttle. That's like 80 mph and it drops rpm fast on the dyno. The original heads with 109k never did that even with the original hard and cracking seals though. When driving normal I don't see any smoke.
Newold1
Post by Newold1 » Tue Mar 12, 2019 10:44 am
Don I see what happened and I hope the valve guides are not a problem now or down the road.
As a suggestion for you and others here on Speedtalk. Whenever you buy parts or items for engines always try to put the purchase on a credit card and when you run into a supplier, shop or vendor like this who is not doing the RIGHT thing to take care of the problem then file a disputed claim with the credit card company and you can have heft that way to make sure they satisfy a problem they have created. Also if you can get them in an email to respond in writing to admit they know they had a problem. Just a suggestion to try and make these problem vendors stand behind their product or give you your money back!
Best of luck on results!
donforeman
Post by donforeman » Sun May 12, 2019 9:22 pm
I gave the van a real test yesterday, pulling the chassis dyno to a car show in Klamath. The engine did really good! The vortec style heads and the ramjet 196 109lc cam work well for towing in a heavy van. The range I use most is 2000 to about 3300 rpm and it just motored up the hills in that range. I haven't filled up again but I think I got no worse than 10 mpg pulling 9860 lbs of van, dyno, gear and trailer up some very steep hills. The ones that have warnings for semis, up and down. It was no big block towing, but it was noticeably better than stock. That's the good news
It worked so well I had to back off and still drive like an old man or I was going to cook my 4l60e transmission. I saw 220 F in the trans pan temp gauge on a 13 mile long grade. I got maybe 6 miles in before I knew I had to back off. That compared to 170ish when the converter stayed locked. Backing off and creeping up the grades like an old man kept it in the 200 range and that was an off an on thing through the entire trip. It has the factory tow package trans cooler after the standard radiator cooler. It has 5/16 lines, but gm made a hokey add on for the towing trans cooler. At the quick connect they took a 5/16 line and necked it down to slide into the other 5/16 line. That part is definitely going away along with a new, larger cooler. My question is the rest of the system is 5/16 and I think the newer 4l60e has 3/8 line probably for good reason. If I upgrade to 3/8 line for flow I would also have to bypass the radiator trans cooler as its threaded for 5/16 line too. I mean it could be adapted and kept in the system, but the point in going to 3/8 is flow. No use running 3/8 into the 5/16 rad cooler. I do have TunerproRT and have the chip keeping the converter locked more than factory, but I think it really needs an upgraded trans cooler and removing the restriction the factory put in the line. Anyone have any insight on upgrading the line size at the cost of loosing the radiator cooler?
Roundybout
Post by Roundybout » Sun May 12, 2019 9:52 pm
I would consider keeping the cooler in the radiator loop. Any extra capacity helps. It also helps to keep the temp stable as well as getting the trans up to temp quicker. I wouldn't worry about a 220 trans temp while towing as that's still in an acceptable range.
