If 50 are good, what about 55?
Frankshaft
Post by Frankshaft » Fri Jun 08, 2018 2:16 pm
Care to discuss? Lol.
GARY C
Re: If 50 are good, what about 55?
Post by GARY C » Fri Jun 08, 2018 2:19 pm
It must be at least 5 better! Anything that kills low-lift flow will always make more power. just ask around.
Warp Speed
Post by Warp Speed » Fri Jun 08, 2018 2:34 pm
I agree with the thread title! Lol
Warp Speed
In general speaking.........true! =D>
GARY C
Post by GARY C » Fri Jun 08, 2018 2:40 pm
Oddly enough most head work increases flow everywhere and almost always produces more power, It's all about timing the window area with the piston position, if not then we would only need one cam shaft for all engines.
FC-Pilot
Post by FC-Pilot » Fri Jun 08, 2018 3:12 pm
If less is more, just think how much more MORE would be.
Paul
Warp Speed
Post by Warp Speed » Fri Jun 08, 2018 3:13 pm
ALMOST always!
I, as some others have also, have seen flow increased, but power does not. How come?
And some flow you don't even bother to measure.......
gnicholson
Post by gnicholson » Fri Jun 08, 2018 3:26 pm
Maybe you guys should skip right over increasing the valve angle and go straight to a spool valve :mrgreen:
groberts101
Post by groberts101 » Fri Jun 08, 2018 3:28 pm
LOL.. at my age I barely have enough balls left under me to use 50's on my current street project.. let alone 55's! :mrgreen:
OTOH, it's only time and money and barring some tragic disease or life altering event, at least I can gain one of those back later on. So, I'll counter that offer with.. what about 52's over 50's? Still doable or any specific advantage for an occasional play toy type street/strip car seeing maybe 2-3K miles/year with rare occasions for work transportation?
8.2" deck 310 SBF(3"x4.060") around 11.6:1 SCR with ton's-o-tricks that low budget guys like me aren't supposed to know, worry, or really care about 8)
Hand ported, angle milled, high-ported(flange plated) Trick Flow 170cc 11R cnc heads w/ 11°/13°(ending up somewhere around 10.xx/12.xx I/E valve angles after angle mill), custom 2.02"/1.54" hollow stemmed tulip shaped valves, and relatively shallow clover style 48cc chambers(53cc stock)
Chopped up and plated 351W Edelbrock Airgap with welded fully divided plenum spacer, not sure on carb size(650-750 Holley) but E85 converted
Mike Jones Hydro Roller 274/279(224/229 @.050)/.612"/.578"(.340" lobe running 1.8/1.7 rockers) w/ NOS Morel .904" solid rollers underneath Conical springs and Ti retainers
Innovators West belt drive w/ under-driven alternator and e-water pump/e-fans only
You know.. just your bare bones basic lightweight street car kinda deal. :^o
Only ordered them last night but here's a stock unmilled 53cc chamber pic to give reference for valve seat design input. And that spark plug looks like it's gonna be pretty tight after a bit of heavier milling.
Any input towards acceptable valve seat designs/valve profiles on this particular head and application?
CGT
Post by CGT » Fri Jun 08, 2018 3:29 pm
Mike Jones Hydro Roller 224/229 @.050/.612"/.578"(.340" lobe running 1.8/1.7 rockers) w/ NOS Morel .904" solid rollers underneath Conical springs and Ti retainers
That's got 55° written all over it!!!! :lol:
"If you pick up a starving dog and make him prosperous, He will not bite you. This is the principal difference between a dog and a man"
GARY C
Post by GARY C » Fri Jun 08, 2018 3:31 pm
ALMOST always!
Care to give a presentage of ones that didn't vs ones that did? Considering the outcome of that vote would it disprove your argument or get you to rethink your position? I doubt it because you are standing on an "always" position from an "almost" stand point!
Is it possible that the flow your not willing to look at could hold the key to what your looking for?
I remember when people didn't bother to look at anything other than exhaust port flow, now most would tell you it they are not concerned with flow.
groberts101
Post by groberts101 » Fri Jun 08, 2018 3:34 pm
The delusionally twisted part of me wants to believe you.. but that laughing emoji has me concerned you may not be serious. :^o :lol:
GARY C
Post by GARY C » Fri Jun 08, 2018 4:04 pm
I would say from the picture of the chamber you would be starting with potential you bon't get in SBC or LS engines unless you go outside the norm.
Frankshaft
Post by Frankshaft » Fri Jun 08, 2018 4:07 pm
Paul
Well, ask Captain Obvious, I bet he would know. After all, to quote him, : "If you travel as much as I do, then you travel a lot, because I do. " Is that sorta the same thing?
GARY C
Post by GARY C » Fri Jun 08, 2018 4:10 pm
Paul
Isn't that one of those "fal·la·cy" thingys? :D
