Max effort inline valve wedge?
Ken_Parkman
Post by Ken_Parkman »
Just curious what there is out there in a max effort combo with an inline valve, stock port configuration and valve angle. I have one guy at 7.0/196 in a full body car. I'm thinking that is up there with a wedge head combo; what else is out there?
swampbuggy
Re: Max effort inline valve wedge?
Post by swampbuggy »
More details on this one guy you're talking about please. Mark H.
Frankshaft
Post by Frankshaft »
6.96. 198 n/a . Mopar wedge in a dragster.
user-30563
Post by user-30563 »
A GM 15 degree around 353 inches runs 6.81/194 in record form in a dragster.
swampbuggy
Ken, what manuf. and what valve angle are you talking about on that deal :?: Mark H.
Ken_Parkman
500 CI AMC with N2O and Indy heads, 18 degree angle which is stock, 2500 lb Gremlin. Good to be different.
Walter R. Malik
Post by Walter R. Malik »
DEFINE "Max Effort" ... within a casting or a bunch of weld to make that casting how you want it...?
Ron E
Post by Ron E »
Ken, was it you that had a pair of Brewer heads on here...maybe a couple of years back? If going for around 500 inches and strictly in-line valves, they'd be worth a serious look.
Keith Morganstein
Post by Keith Morganstein »
Ken_Parkman wrote: Mon Jun 18, 2018 11:49 pm 500 CI AMC with N2O and Indy heads, 18 degree angle which is stock, 2500 lb Gremlin. Good to be different.
Power adder? There’s s blown B1 head Mopar powered dragster that runs in the 5’s.
gmrocket
Post by gmrocket »
397 small block Olds, 6 degree valve angle.
6.59@206
Ken_Parkman
Does not really matter Walter, just curious on how far a wedge has been pushed. This particular one is within the original head casting.
I've never worked on Brewer heads; do like the look of them. There is probably a bit more there with the height of those things, but I'm also thinking not much. The indy is pretty good on flow/valve area, and both are stuck with the same wedge valve limits. Time to go canted.
I figured there would be some fast B1 head Mopars out there. There's also an Indy head twin turbo AMC dragster on the 235 mph limit for top dragster.
Never thought of the Olds, but it sure makes sense. Is that a door car? Batten head?
gmrocket
Post by gmrocket »
Batten headed dragster
Still not bad for a head from the 70's
Post by pdq67 »
AMC 500CI - Bulltear.com
Guys still building these engines?
