Piston wrist pin length
ptuomov
Re: Piston wrist pin length
Post by ptuomov » Tue Nov 26, 2019 10:16 am
Mark O'Neal wrote:
Sat Jun 30, 2018 9:50 pm
There are countries that measure using the metric system...and there is a country that went to the moon, built the most powerful military in history, as well as the largest industrial base ever...... :P :P
Did the Chinese go to the moon yet? I thought they only had that military guidance satellite installed on the dark side of the moon just on the right orbit.
Here's another question relating to the pin-to-boss overlap. Does the rod small end to pin boss clearance need to be minimal for this kind of small overlaps to survive? My logic is that a lot of exposed pin between the rod small end and the piston pin boss lead to the pin bending and that can't be good with this little overlap between the pin and the pin boss.
Mark O'Neal
Post by Mark O'Neal » Thu Nov 28, 2019 4:00 pm
.040 per side is our goal.
Rod manufacturers make this difficult.
ptuomov
Post by ptuomov » Fri Nov 29, 2019 7:48 am
.040 per side is our goal. Rod manufacturers make this difficult.
This will get custom rods from a forging intended for 6.2" rods, so I assume we can get whatever small end width we want.
Mark O'Neal
Post by Mark O'Neal » Fri Nov 29, 2019 6:10 pm
I've seen them from 1.000 to 1.060....so getting the pinboss span from your pistons guy wouldn't be a bad idea. And make sure to beam offset is correct.
ptuomov
Post by ptuomov » Fri Nov 29, 2019 6:22 pm
The rod big ends will be asymmetric but the plan is to have the rod bearing mid point under the beam centerline and the beam centerline exactly under the middle of the piston.
Mark O'Neal
Post by Mark O'Neal » Sat Nov 30, 2019 1:47 am
So....definitely not a Ford.
ptuomov
Post by ptuomov » Sat Nov 30, 2019 1:32 pm
No, not a ford.
This is an old and obsolete Porsche V8 from a ‘87 928 S4.
Bore offset is 25mm, journal is 52mm, rod big ends are 27mm wide, stock rods were produced by cutting 2mm off from the one side of symmetric 29mm wide 944 rod. The rod beam is centered relative to the piston and the rod bearing in the front back direction. Stock PPF rods are very strong but also very heavy at 860g for 150mm rod.
GLHS60
Post by GLHS60 » Wed Dec 11, 2019 4:54 pm
I believe I can help..
Think of it this way, logically...not some old outdated dictionary definition ..
Engines run on combustible fuel.
Motors run on electricity.
Thanks
Randy
Mark O'Neal wrote:
Sun Jul 08, 2018 4:03 am
Thrice
Sherwood Park
Alberta,Canada
Mark O'Neal
Post by Mark O'Neal » Fri Dec 13, 2019 9:49 pm
Thanks
Randy
Thrice
www.dictionary.com
learn to speak English.
ptuomov
Post by ptuomov » Sat Dec 14, 2019 2:16 pm
Is this thread turning into a piston wrist pin length measuring contest?
GLHS60
Post by GLHS60 » Sun Dec 15, 2019 3:38 am
Sorry to derail, I was only joking with my old pal Mark.
He likes to use ancient words like thrice.
Thanks
Randy
Sherwood Park
Alberta,Canada
Mark O'Neal
Post by Mark O'Neal » Sun Dec 15, 2019 11:59 pm
And Randy likes to cruise the lake in his engineboat.
GLHS60
Post by GLHS60 » Mon Dec 16, 2019 2:55 am
Bless you my friend, you got me!!
Thanks
Randy
Sherwood Park
Alberta,Canada
ptuomov
Post by ptuomov » Sat Jan 04, 2020 12:40 pm
Here's a custom 10mm piston mockup by Mahle and the pin bosses are similarly really skinny. The specified pin is built like a brick house, but it doesn't overlap too much with the pin bosses in the piston!
Photo:
ptuomov
Post by ptuomov » Wed Feb 12, 2020 3:27 pm
Another picture of 1987 vs 2020:
