Piston wrist pin length
LSP
Re: Piston wrist pin length
Post by LSP »
ptuomov wrote: Fri Jun 29, 2018 7:17 am I’m looking at Mahle 100mm Subaru pistons with 23mm diameter piston wrist pins. The bare piston weighs 406g. The wrist pin is about 57mm long. The gap between pin bosses (for the rod small end) is about 29.5mm. This leaves about 13.75mm (0.54”) of pin inside the piston per side when the pin is perfectly centered. Seems low, no? Must be thoroughly optimized. Welcome to the modern era.
What is the motor's intended use?
ptuomov
Post by ptuomov »
LSP wrote: Thu Feb 13, 2020 7:27 am
Street car, 5.0L, 93 octane pump gas, twin turbo, 8000 rpm fuel cutoff, 78.9mm stroke, probably about 800 lbf-ft torque over a fairly broad power band.
Put Search Keywords Here
LSP
Post by LSP »
ptuomov wrote: Thu Feb 13, 2020 8:14 am
Putting Subaru pistons in a V-8?
ptuomov
Post by ptuomov »
LSP wrote: Thu Feb 13, 2020 5:16 pm
They didn’t end up being Subaru pistons but custom pistons from another 100mm forging. The overlap between the pin and the boss is similarly short, and the pin walls are stupid thick.
LSP
Post by LSP »
ptuomov wrote: Thu Feb 13, 2020 5:32 pm
Can you show a pic of your piston from the bottom? And how thick is it in the center?
ptuomov
Post by ptuomov »
Here:
LSP
Post by LSP »
How thick is it in the center?
ptuomov
Post by ptuomov »
LSP wrote: Sat Feb 15, 2020 12:02 pm How thick is it in the center?
I don’t have the numbers here on the ski slopes, but it’s really thick. We wanted both ring lands to be really tall, and that allowed the crown to be really thick even in the center. From memory, something like 10mm, but I may be misremembering that.
The pin is short but 5.5mm wall thickness and 24mm diameter.
ptuomov
Post by ptuomov »
It’s not quite 10mm, the thinnest part of the crown is 6.7mm/0.264” which is still very thick.
