Idea for pre lubing oil galleries
Schurkey
Re: Idea for pre lubing oil galleries
Post by Schurkey »
swampbuggy wrote: Mon Jul 02, 2018 11:58 pm first time on the dyno...and EVERY time there after.
Strikes me as "stirring making the tea sweet, not the sugar".
Too much time, money, effort, and enthusiasm being wasted on nothing important. A bazillion engines every day get fired-up without being pressure pre-lubed.
CharlieB53
Post by CharlieB53 »
I’ve thought long ago but never got around to doing it.
An elec pump T’d into the oil filter adapter and a Merphy switch such that the pump comes on with the key near immediately pressurizing the oil system to a minimum psi. Crank and start and as the engine oil pressure rises the Merphy turns off the electri pump.
Relatively modest insurance for any expensive toy.
tuffxf
Post by tuffxf »
Gday,
That is exactly as 90% of the large earthmoving equipment i work on are set up.
There is good documentation out there as to the increase in engine life by doing this.
Cheers
Kevin Johnson
Post by Kevin Johnson »
jake197000 wrote: Wed Oct 09, 2019 3:12 pm I made mine out of an old 30 lb Freon tank works like a champ.i also turn the engine by hand as it is pumping
Can you describe in more detail what you did?
I know some people have used similar tanks in combination with pre-oiler cylinders so that the full stroke of the piston is supplying high pressure oil.
swampbuggy
Post by swampbuggy »
Thanks for ALL the information all of you folks have placed into this thread, Mark H. =D>
