What differences are there between the carbed engines and the later model FI engines? I vaguely remember that you can’t use a carb manifold on the FI heads...different bolt pattern iirc, but are the blocks basically the same? Can you use earlier (or aftermarket) heads on the FI blocks? Any difference in flexplates? Anything else significantly different?
There is a guy down the road from me that bought up a bunch of motor homes that where destroyed in the Great Hailstorm of 2016, but due to health issues he is letting go of most of his collection go for peanuts. He has several FI 460/C-6 setups I am interested in.
460 ford engines differences
Re: 460 ford engines differences
Realistically ... only the heads on up although, the valve train is the same.travis wrote: ↑Wed Aug 01, 2018 4:09 pm What differences are there between the carbed engines and the later model FI engines? I vaguely remember that you can’t use a carb manifold on the FI heads...different bolt pattern iirc, but are the blocks basically the same? Can you use earlier (or aftermarket) heads on the FI blocks? Any difference in flexplates? Anything else significantly different?
The front cover is slightly different with no fuel pump provision and smaller corner oil pan bolts.
The 460 FI heads have no heat crossovers. The head bolt pattern must be the same since I use my original 429-460 torque plate on 'em.
Monty Frerichs
B&M Machine
B&M Machine
Please note that the Exh ports on any 460 factory iron Head flow a miserable 58% of the Intake !
If your sticking with the iron Head and are looking for more then a 35 hp gain while sticking with the stock compression then in the least you need to have Exh side fully ported by someone who can guarantee you no lost of low lift flow !
In short it's really best to stuff in a oversize Exh valve while doing the porting work!!
So are the earlier carbureted engines from 1978 up.
