Giving a talk on cam selection, and need your input
CamKing
Post by CamKing »
I'll be giving a talk on cam selection, and need some help.
What questions need to be covered?
What common mistakes do people make?
What would you like to learn about cam selection?
JoePorting
Re: Giving a talk on cam selection, and need your input
Post by JoePorting »
How do you select a cam based on head flow numbers?
Joe Facciano
Curtis Mc
Post by Curtis Mc »
Do you know the level of understanding of your audience? That would drive the level and complexity of the questions, based on where they 'should' be on camshaft knowledge. For example is this for - novices, intermediates, experts, professionals? It may span more than one, but unlikely all. This would then help build out how low or high the conversation will start and then finish.
roc
Post by roc »
Do you have hot cams for Tesla or Chevy Volt? :lol:
Sorry man, I couldn't help. I wish I was in the audience of this Cam Talk by Mike. Any chances to be filmed and go to YouTube?
Tuner
Post by Tuner »
Explain why different cams with very similar lift and duration numbers need different springs, seat pressure, spring rate, etc. What advantage or disadvantage is found comparing cams which require more or less spring pressure or spring rate. Describe the effect on HP and Torque of cams which require more or less pressure/rate.
Tuner
Post by Tuner »
Curtis Mc wrote: Thu Aug 09, 2018 2:08 pm Do you know the level of understanding of your audience? That would drive the level and complexity of the questions, based on where they 'should' be on camshaft knowledge. For example is this for - novices, intermediates, experts, professionals? It may span more than one, but unlikely all. This would then help build out how low or high the conversation will start and then finish.
The way people rise above the level of novice is through exposure to expert knowledge and to engage in conversation with people deemed to be expert.
CamKing
Post by CamKing »
This will be during The Race Engine Challenge competition in October. So I'm assuming everyone will be above novice.
CamKing
Post by CamKing »
JoePorting wrote: Thu Aug 09, 2018 2:07 pm How do you select a cam based on head flow numbers?
I don't, actually.
I use the flow numbers to calculate the "Effective CSA" of the ports.
Post by pdq67 »
You might talk a bit about the differences between, "balls-out", high rpm race cams, and, wide power and torque, "street", cams.
BigBro74
Post by BigBro74 »
Just spitballin’ here mike , but in my experiance, I would start with the rationale (what you see as important, your approach) for how you pick cams. You need to be yourself!
Make a list of what you think the important points of picking cams are and I would bet the common mistakes you want to cover will become appearant fast.
Sorry that you already know all of this -but the point I guess that I am trying to make is that if this talk is a face to face class type of situation-be authentic by being yourself and giving your honest assessments. The students will want that or they will just be thinking “same Thing as everywhere else” (at least that is how it goes with my HS industrial technology students) - hopefully the people you are talking to won’t take as much convincing as the teenagers lol-
Jason
BigBro74
Post by BigBro74 »
Tuner wrote: Thu Aug 09, 2018 2:18 pm
This
JoePorting
CamKing wrote: Thu Aug 09, 2018 2:27 pm
I don't, actually.
How do you use the Effective CSA of a port when selecting a cam?
Joe Facciano
speedtalk
Site Admin
Site Admin
Post by speedtalk »
CamKing wrote: Thu Aug 09, 2018 2:03 pm What questions need to be covered?
How is the choice of lobe family made?
In Memory of Don Terrill
SpeedTalk Owner/Admin
Steve.k
Post by Steve.k »
How will higher lift affect where the engine makes power?(or does it?) Everything else left the same.It may give gains in output but does it affect where the engine previously made hp. As does duration? And if heads peak flow at say .700 is there any gains designing cam for .750-.800 lift? I wouldn't mind knowing the answers to those questions Mike.
Sophosis
Post by Sophosis »
Factors to consider when choosing a cam for an overhead cam application versus a cam-in-block application. Finger-follower vs bucket action.
