New Old Stock Pistons
amc fan
Post by amc fan » Wed Aug 15, 2018 3:21 pm
I have a set of Pistons that need lateral gas ports, lightning, wrist pin Oilers and skirts to be coated, I remember somebody posted on here a company that does it but I could not find it. Can I get some suggestions from you guys. Thanks
ProPower engines
Re: New Old Stock Pistons
Post by ProPower engines » Wed Aug 15, 2018 4:19 pm
Almost any piston company that offers that option will do it.
If you send them to the original manufacture I am sure that they will machine them as they would be set up
to do it.
There is a fixture you can get to do vertical gas ports on ebay which is well made. I have is and it works great.
You just need a mill or drill press you can bolt it down on the table.
ptuomov
Post by ptuomov » Wed Aug 15, 2018 4:26 pm
Rebco Machine?
amc fan
Post by amc fan » Wed Aug 15, 2018 4:57 pm
Rebco that's it. The piston manufacturer is out of business. I see someone makes rings with lateral grooves cut in them if you can get them in your size . Thanks for the help guys.
Post by PackardV8 » Wed Aug 15, 2018 5:12 pm
Coatings are not as easy as it might seem. Many coating services won't guarantee their process unless the material is new-from-the manufacturer.
Their explanation is it's likely parts having been handled, on the shelf, in and out of the box, have picked up contaminants.
SupStk
Post by SupStk » Wed Aug 15, 2018 5:47 pm
Calico will coat used pistons.
Monty Frerichs
B&M Machine
Ericnova
Post by Ericnova » Wed Aug 15, 2018 8:22 pm
Total Seal just introduced their "gas ported" rings, with slots on the topsides.
