Large Vortec bowtie, Engine?
Re: Large Vortec bowtie, Engine?
Post by F-BIRD'88 »
Are you sure that the seeming soft pull off the corners is not really a traction problem? Chassis setup gearing.....
bigfoot584
Post by bigfoot584 »
Curious going thru all the posts, I may have missed it sorry, if I did
but I didn't see anything on his LSA, that would have an effect on
the engines performance, if it's out of the ballpark from where
it should ???
88bluestar
Post by 88bluestar »
COMP CAMS grind #CS 6262/6263 S 108.0 PART # 12-000-47 4/7 SWAP
.020 DURATION 281 285
VALVE TIMING OPEN CLOSE
.050 INT 22 BTDC 50 ABDC
EXH 60 BBDC 16 ATDC
DURATION @ .050 252 INT 256 EXH
LOBE LIFT .361 .367 LOBE SEPERATION 108.0 (SPECS ARE 104.0 INTAKE CENTERLINE) 1.5 roller rockers
36 degrees timing, 4000 ft above sea level, 780 holley mech secondary DP built by Sean Murphy Induction. primary is 74, secondary is 82 jets with 91 pump gas. 9.5:1 comp, 355 cid
7000 max rpm rule/ currently running a 7.00 gear final. rear stays hooked up, no tire spin
Post by F-BIRD'88 »
Move the cam to a 100 deg in c/l.
Then,try reducing the gear ratio a bit.
Post by F-BIRD'88 »
Being at 4000 ft , I'd bet that the front runners are running (a lot ) more than 9.5:1 CR.
rustbucket79
Post by rustbucket79 »
So are you planning to change the heads or work around what you have?
How do they enforce the rules? Do they even bother?
rocketracer380
Post by rocketracer380 »
i would be interested in buying if they are 225
88bluestar
Sometime early november is when I'm done racing this year. Plan to pull them off, clean and cced to know for sure what I have. F-BIRD88, the max is around 9.8 without being illegal, and I had wanted to run a thinner head gasket but what little cash I have is to go racing on the weekend so Im waiting off tearing into it until the season concludes. Rocketracer380 I will touch base with you once I'm done, see if you're still interested at that time, and if they are what you are looking for.
6.50camaro
Post by 6.50camaro »
How do they check CR? Dan
rocketracer380
ok kool let me know
88bluestar
6.50camaro wrote: Tue Sep 18, 2018 6:07 am How do they check CR? Dan
katech device for checking compression ratio.
6.50camaro
Have you had your motor checked to see what the CR is with the whistler . You are giving up 5 cu.in. on engine size how much compression are you giving up. Top runners push the rules to the limit most of the time .
PS . Your cam is better suited for 11.0 to 1 CR than 9.5 and the intake runner csa is not helping you. IHMO Dan
88bluestar
Wish I could run a different cam but don't really have sponsorship to do it right now. I know what you mean about rules,.....The winners always take full advantage of the gray areas but right now lack of money us hurting me. Hoping to get help in the offseason to make drastic changes.
6.50camaro
I totally understand money issues. My racing has always been funded by overtime pay and buying and reselling parts .
You can start by running a little more lash on the intake ,try .005 more . If it responds positively try advancing the cam to 100° icl w/ normal lash like I think F-bird mentioned.
Then try more lash agan with the cam advanced. This will help zero in on IC position to give you better dynamic CR and better pull off the corner. It only will cost time and a few gaskets. If you can do these things before the off season it will help you know where to focuus your energies .Good Luck Dan
Don't forget to check intake PV clearance advancing the came.
Tuner
Post by Tuner »
Anyone who has actually run these heads has no comment about the OP saying he used 36 degrees spark advance with this head which GM identifies as "Fast Burn" and advises 28 ~ 32 in the instructions they supply with the part?
