Your opinion.....ring gap for n/a 434 sbc
rewguy
Post by rewguy » Thu Oct 11, 2018 11:05 pm
13 deg. 15-1, race gas, drag race, total seal ap top rings, Napier second. Std. Tension oil ring, vac pump.
Mark O'Neal
Re: Your opinion.....ring gap for n/a 434 sbc
Post by Mark O'Neal » Thu Oct 11, 2018 11:40 pm
.018 - .021
Or more.
cjperformance
Post by cjperformance » Fri Oct 12, 2018 5:53 am
Piston material?
Block filler?
Target run temp?
More info.
Craig.
Frankshaft
Post by Frankshaft » Fri Oct 12, 2018 8:00 am
I would set them at .024 and .030 2nd.
rewguy
Post by rewguy » Fri Oct 12, 2018 9:07 am
2618 forged. Probably 175 degrees race temp. No block fill. Darr lil m block.
engineguyBill
Post by engineguyBill » Fri Oct 12, 2018 10:16 am
.0045" to .0055" per inch of cylinder bore for the top ring; .0060" to .0070" for the second ring.
Bill
SAE Member (28+ years)
"Do what you can, with what you have, where you are."
- Theodore Roosevelt
steve316
Post by steve316 » Fri Oct 12, 2018 7:12 pm
I would go with mark's recommendations for the top ring and open up the second ring to .025
steve316
Post by steve316 » Fri Oct 12, 2018 7:15 pm
Why are you running a standard tension expander with a vacuum pump?
ProPower engines
Post by ProPower engines » Fri Oct 12, 2018 7:21 pm
Are the pistons gas ported in any way ???
And why a std. oil ring with a vac. pump?? Why no go with a low tension oil ring?? Issues with the combo before??
rewguy
Post by rewguy » Fri Oct 12, 2018 10:01 pm
no reason. I just put back exactly what was in there.
induction apprentice
Post by induction apprentice » Fri Oct 19, 2018 6:10 pm
Top .027"
Second .030"
af2
Post by af2 » Fri Oct 19, 2018 7:06 pm
Then run it the way you did.
Why people set them at the closest they will ring butt is beyond me!
GURU is only a name.
In-Tech
Post by In-Tech » Sun Oct 21, 2018 4:00 am
I'm with ya Adam, there isn't enough TIME, at any kind of reasonable racing rpm,for a couple thou extra to make a difference, gap within reason and put extra safety to it if you are worried about having to chase your tune.
Then put a vacuum pump on it and fuggit 'bout it. :lol:
-Carl
