Page 1 of 1
Piston shape and detonation.
Posted: Wed Dec 12, 2018 9:03 pm
by The Badger
So ive spent the last few days going over what i could find on the internet and what few papers i have on the stuff and ran across the "super squish" pistons that Larry Widmer( "oldone" on the fourm i believe) developed. From what i researched, it seems as if it started with nascar in the 80s and 90s and spun into the air cooled vw market. Now while reading up on this i came across alot of people saying that the cam and chamber had to be just right for the pistons to work. I also ran across a few pictures of what i imagine the pistons are. My questions are as follows.
1. If cam events matter what would it be? Is the cam required to bleed of the excess compression? So static is high but dynamic in the normal range. Or is this piston making it so both can be higher?
2.are we just aiming to make the most squish area by using intake dome to force charge over to exhaust?
3.is there a noticable amount of charge that gets stuck on the other side of dome and is unburned almost like in the top ring land?
Re: Piston shape and detonation.
Posted: Wed Dec 12, 2018 9:18 pm
by hoffman900
On a 4 valve engine, you need to look at what the sportbike manufacturers are doing. They're routinely selling street bikes from the factories with 12.5:1-13:1 compression for pump gas, on bores as large as 4.40" (Ducati).
Here is the Ducati:
A lot of it is in the mixture motion in the chamber. Ducati has been students of Keith Duckworth and were noticeably ahead of the Japanese in refining this technology (obviously the Japanese finally figured it out and refined it too). The other is modern EFI and engine management systems (being able to run the engines right on the edge of detonation). Also, lots of time spent on cooling passage design and removing heat helps quite a bit.
The rules do apply, lower smoother domes are always better. Squish is probably as much as you can get away with. The other is run the top ring as high as you can, safely. Look at a modern OEM piston design or a highly developed NA race engine (NASCAR). Very little crevice volume.
I know some people have a lot of respect for Larry, but some of his accomplishments were found to be false (like the SCCA MGB he told a story of on his site), the VW guy seems to have some of the same black magic thing going on too. Reading about either leaves me with the "that's kind of what's happening but not really" feeling...
Posted: Wed Dec 12, 2018 9:47 pm
by hoffman900
I think another good example would be the NASCAR engines, for 2 valve applications. They're spec'ed at 12:1 compression ratio, and the valve angle of the heads affect the shape to some degree, but no doubt they've poured tens of millions of dollars in improving the combustion efficiency.
and chambers like this:
Posted: Thu Dec 13, 2018 6:25 am
by Truckedup
double post
Posted: Thu Dec 13, 2018 6:28 am
by Truckedup
Truckedup wrote: ↑Thu Dec 13, 2018 6:25 am
Does NASCAR specify valve arrangement or combustion chamber shape?
Posted: Thu Dec 13, 2018 7:44 am
by The Badger
Truckedup wrote: ↑Thu Dec 13, 2018 6:28 am
The limit compression now, think that started in 90s. Used to be run as much as you want.
Posted: Thu Dec 13, 2018 8:15 am
by Newold1
My feeling about "SQUISH" is that the squish activity in the cylinder takes place when the flat top areas of the pistons come up and meet areas of the flat head deck surfaces that are not open to the chamber itself. The possible changes that can make differences here are the size of the gap in these areas as the piston approaches and reaches TDC and the remaining top shape of the top of the piston open to the chamber. Another thing to consider is that in some combustion chamber sizes and shapes is that domes depending on shape and size can actually interfere with the action of squish. I think this is the reason in newer head design chambers and piston top shapes the tendency now is to make the chamber smaller and more centered and reduce or eliminate domes as much as possible. JMHO
by hoffman900
The heads are homologated pieces, but are a blank slate circa about a decade ago. The chamber can be any shape, just that the valve included angles will dictate the shape. That said, being blank sheet designs, it’s all optimized.
Posted: Thu Dec 13, 2018 8:58 am
by Truckedup
I know you all hate bike stuff, but my vintage Triumphs are a perfect example of high dome pure hemi chambers....
This is a piston shape used by my competitors about 12-1
This is what I use, 10.5 compression
I'm just a hobbyist engine builder but it seems obvious that my pistons give up compression for a faster flame travel, quench and makes the same power with less compression ,milder cams and smaller carbs...Those tall domes are just heat collectors and I believe interfere with the way the air fuel mixture enters the cylinder
Posted: Thu Dec 13, 2018 9:16 am
by hoffman900
I agree with you 100%.
I think domes like that are just builders not seeing the forest (good combustion) for the trees (compression, more is better!!!).
Posted: Mon Feb 11, 2019 11:39 am
by The Badger
So talking about flame travel wouldnt it be better with the design of the pistons larry made? Just looking at what ive seen (which i know is not a scientific test) with the pistons and what not, it would seem you could get the best of everything with design.
1. Higher compression becuase of dome on intake side
2. Supposedly dense charge at spark plug.
3. Less area to expand across for a faster burn.
4. No milling head to get the smaller and lower cc chamber that can effect flow amd pressure recovery(which im still trying to understand fully)
Please tell me if im wrong or on wrong track with my thinking. Great to be back on fourm and thanks to all who got it going and especially to Dons family for keeping it going.
Posted: Mon Feb 11, 2019 8:07 pm
by Newold1
I don't think intake charge motion is as affected by a taller dome during intake opening until closing much because the the piston and it's dome will be down substantially in the cylinder when the intake event and charge is entering the cylinder via the chamber and valve opening. There is no appreciable squish occuring at this point as that takes place when the intake has already closed and the piston and dome are up near TDC. The secret seems to be that the actual squish generation and motion imparted to the fuel charge can be restricted and affected by a major dome obstruction that is then in the chamber.
I think this is what Larry was talking about with his years of DOHC 4 valve piston dome size and shape as well as chamber size and shapes iterations.
Posted: Mon Feb 11, 2019 8:49 pm
by Ron E
Truckedup, those 12 to 1 pistons are scary. Looks like they came from an air compressor.I don't blame you from taking a different approach. Many pre WWII engines were similar. They were very under-square and used steep valve angles to gain valve area in the small bores.. The available gas was too weak to support much CR so the domes, while ugly, weren't as awful as those 12 to 1's. They were running 6, or less to 1
I like seeing engine builders take a platform and innovate/refine to unheard of levels.What are the valve angles on the Triumph's you race. Looks like it's closing in on 90° included.
