Camshaft Advise
RWILLIAMS
Camshaft Advise
Post by RWILLIAMS » Mon Feb 11, 2019 8:13 pm
Building new motor for dirt car 350 60 over 906 vortec heads 4 vr hyper pistons stock crank and rods Victor Jr copy intake 600 single line Holley on e85 also 750 dual line 750 depending on track stock rockers 2700# car 3/8 and 1/2 mile banked track probably min 3500 rpm in corners 6500 to 6800 rpm and of straight. I have a comp 280 camshaft that's free i personally don't think it's big enough myself any thoughts on this or a offshelf recommendation i am looking at an Elgin grind with 500 lift 302 advertised duration 106 lobe separatition 3200 to 6500 power range I like everything about can but I think it's a bit much on duration help
RWILLIAMS
Re: Camshaft Advise
Post by RWILLIAMS » Mon Feb 11, 2019 8:18 pm
I don't mind a custom grind either just trying to get some ideas. Thanks
Re: Camshaft Advise
Post by pdq67 » Tue Feb 12, 2019 7:58 am
Try here.
http://jonescams.com/
7859 Commerce Dr.
Denver, NC 28037
Phone: (704)489-2449
Fax: (704)489-2450
Email: jonescams@bellsouth.net
Hours: M-F, 9am-5pm
I would say call UDHarold, but my friend Harold is long gone.
Bullet Cams ended up with Harold's lobe masters?
The new home for UDHarold's UltraDyne Cams!
Call us at (662)893-8022 for the original UltraDyne power and quality with the quick service you've come to expect from the crew at Bullet!
CamKing
Re: Camshaft Advise
Post by CamKing » Tue Feb 12, 2019 10:04 am
Mechanical or Hydraulic ?
Mechanical Flat Tappet
SBCM, M72352-73359-106
244/248 #.050"
.352"/.359" Lobe Lift
106 LSA
Hydraulic Flat Tappet
SBCH, H74333-76333-106
238/243 #.050"
.333"/.333" Lobe Lift
106 LSA
67 Nova
Re: Camshaft Advise
Post by 67 Nova » Tue Feb 12, 2019 10:39 am
Really, call Mike Jones.
I'm really impressed with his way of doing business. Weather right or wrong, PC correct or not, he will be straight up with you and not blow smoke up your ass. EVEN if it means costing the sale.
The man grew up around cams and stuff, and unlike others on this site, he's not just a salesman that farms work out.
