before/after 383 dyno results
Re: before/after 383 dyno results
- Stan Weiss
I see a number of sheets of information have been posted but do not see these posted.randy331 wrote: ↑Tue Apr 16, 2019 10:13 pmthe bsfc #s were about I expected, and way better than they were.
only headerz tested was his 2" ones he has for his car, and the 1 3/4 x 1 7/8 step dyno shop headerz.
Spacer helped a little.
Pan is not a good pan, just what he had.
Ran vp blue, then q16.
As far as restriction, there is always one. Every engine has a restriction.
But, restriction elimination ability is very budget dependent.
Randy
Now thats some technical shit,lol
I should have been more specific on the BSFC, any noticeable dips related to induction
Tom
Give me a bit and I'll pm you.
Busy preparing for my seminar now.
Randy
- Stan Weiss
Randy,
You ignore my post asking about BSFC.
You tell zums you will PM about BSFC.
Conspiracy Theory? Or is there really something about the BSFC data that you trying to hide?
While taking a completely unnecessary and juvenile stab at DV.Stan Weiss wrote: ↑Wed Apr 17, 2019 2:50 pm Randy,
Here, this might help some of you understand this better.
Rick
Rick
Not looking to muck up y'alls thread but why not just post the actual dyno sheet that you guys would ask of others?
I understand this post is just you being a richard towards David, but if you guys are really all you claim to be then why do you have the need to attack people that are not even claiming the magic numbers that you guys claim?
Shouldn't you engines speak for themselves... Do they!?
I don't think the platform you are using is designed to fudge the numbers but for some strange reason you guys think that about eveyone, (with the exception of knightengines) for some reason, it would seem if you were looking to educate people on spotting faulty dyno sheets you would want to post dyno sheets.
- Stan Weiss
So I guess then something like this is out of the question.
Exactly Steve, that one has about 375 more dyno pulls than this 383 has on it. It kinda turned into a dyno/test mule. It's still sitting here in my shop after a angle mill the heads dyno test session, but hasn't been put in anything and ran at the track yet.steve cowan wrote: ↑Tue Apr 16, 2019 11:31 pm apples to oranges comparison in my opinion-
13.1 engine budget and time restraints and needed to reuse some parts.
700 hp 11.1 engine- 50 pages of information on this forum
Not sure where it will end up.
But, some of what we learned on it can be transfered to other engines.
Randy
Well...looking over things. Fuel flow is up and BSFC's are better and better for longer. That explains where the power came from. The 40°ignition timing was pretty much a wash from 35°....down 3 total average hp...probably a good sign. Didn't know if you had looked at that yet.
- Stan Weiss
Fuel Flow up with same BSFC increased HP
Same Fuel Fflow with decreased BSFC increased HP
Unless the A/F ratio had a change, Fuel Flow up means SCFM up and VE % up.
But we will really never know because this data will never be shown to us. Will it?
BSFC dont look bad, definitely no red flags just the typical higher rpm higher number that looks like it could all be jet related, what are the asterests after pull titles, number of pulls or side notes, you should talk him out of those 2"pipes, im sure hes happy either way.
Tom
Tom
Number it pulls. When a pull is made without changing the name it’s adds and asteret after the title.zums wrote: ↑Thu Apr 18, 2019 1:04 pm BSFC dont look bad, definitely no red flags just the typical higher rpm higher number that looks like it could all be jet related, what are the asterests after pull titles, number of pulls or side notes, you should talk him out of those 2"pipes, im sure hes happy either way.
Tom
“Pure logical thinking cannot yield us any knowledge of the empirical world; all knowledge of reality starts from experience and ends in it.”
Albert Einstein
Albert Einstein
