Ported Chevy 083 heads, the tpi project
Re: Ported Chevy 083 heads, the tpi project
I'm guessing this runner is only for the Northern Hemisphere
Silliness aside, you have some serious cutter skills.
Thanks Rev, After more work and very small gains I decided to just put a radius on the stock runners. Notice the messy red sharpie. This is also aimed at my friend "T" who is working on his tpi truck as well. This mod is within 3 cfm at every lift of very modified slp cut up and much larger runners. Input welcome. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
When I put the stock size round gasket on the stock lower, getting ready to install the runners. Just the gasket reduced the flow 3 cfm. Then I tried it with the Edelbrock lower and it did the same thing. It just reduced the radius. Going to the Large gaskets make the biggest gain I guess its like flowing without a clay radius.
Charlie regardless of #s I guarantee unless your friend cams it wrong its going to run harder than he imagined, btdt.
He will be real happy and your hands may not be numb...one day lol
Flow at this point
.05 38.6
.1 72
.15 104.7
.2. 134
.25. 159
.3 185
.35 198
.4. 216.1
.5. 240.7
.6. 241.6
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
.05 38.5
.1 71.5
.15. 108.5
.2. 139
.25. 168.7
.3. 195.3
.35. 217.1
.4. 235.1
.5. 251.7
.6. 254.7
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Charlie,
whats that step area around the exhaust valve,never seen that before
Chamber around exhaust is very much stock shape. This is 083 casting before the Vortec chamber. Thanks, Charliesteve cowan wrote: ↑Mon Mar 18, 2019 2:30 amCharlie,
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Steve, if you are asking how I change the chamber from quench to exhaust side then I do that to help flow when piston nears tdc to add flow to the long side of exhaust port. I wish there was more material there to give a better shape. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Your ex valve is in the intake path, you can round the edge & or sink the valve, should help
Steve, I do not have the valves that will be used for this build so I can't finish the valves, guides or seats just the way I would like. So What you see in the pics are development parts and cuts. Yes, if you are talking about the face edge of the exhaust valve I do like to round that edge. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
I never thought about what you are saying Steve, That rounded edge on the exhaust valve will influence intake flow. That is good. Thanks, CharlieCarnut1 wrote: ↑Mon Mar 18, 2019 10:24 amSteve, I do not have the valves that will be used for this build so I can't finish the valves, guides or seats just the way I would like. So What you see in the pics are development parts and cuts. Yes, if you are talking about the face edge of the exhaust valve I do like to round that edge. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
.05 37.3 37.6
.1 70.5 70.6
.15 103.6 104
.2 131.2 130.7
.25 152.3 154
.3 170.2 172
.35 183.8 186.3
.4 194.3 196.3
.5 207 207.4
.6 211.2 209.9
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Carnut1 wrote: ↑Mon Mar 18, 2019 3:45 pm After Chamber work I assembled the whole manifold with modified slp runners and radiused stock runners. very interesting results.
slp runners tpi runners
.05 ( 37.3 ) ( 37.6 )
.1 ( 70.5 ) ( 70.6 )
.15 ( 103.6 ) ( 104 )
.2 ( 131.2 ) ( 130.7 )
.25 ( 152.3 ) ( 154 )
.3 ( 170.2 ) ( 172 )
.35 ( 183.8 ) ( 186.3 )
.4 ( 194.3 ) ( 196.3 )
.5 ( 207 ) ( 207.4 )
.6 ( 211.2 ) ( 209.9 )
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
