Ported Chevy 083 heads, the tpi project
Carnut1
Re: Ported Chevy 083 heads, the tpi project
Post by Carnut1 » Thu Mar 21, 2019 10:18 am
F-BIRD'88 wrote:
Thu Mar 21, 2019 9:31 am
Are u flowzin the base+ head with a generous radius (putty) at the base inlet? Great thread.
About 3/8" clay. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
RevTheory
Post by RevTheory » Thu Mar 21, 2019 11:02 am
What cfm would you like to see for a 6,000 peak rpm 350, Charlie?
Carnut1
Post by Carnut1 » Thu Mar 21, 2019 11:56 am
I have been thinkin about that Rev. I would like 250 cfm but at this point 220 cfm will have to do. I am only a few cfm from this on cylinder #1 which should be the worse runner. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 » Fri Mar 22, 2019 7:01 am
Quick test of 48 mm t.b. with radiused tpi runners. This throttle body only loses 4.7cfm @ .5" lift over larger aftermarket (bbk) throttle body. So not much of a restriction there. It did come with an ugly center filler piece. It would be of interest to see how drivability and tip in are different with the two. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 » Sat Mar 23, 2019 4:09 pm
Can you say "Pushing your luck."? Can't kick me for trying. I would like some input on this new texture. I call it "Smear". 90 degree lines against flow with bumps. Super easy to do. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 » Sun Mar 24, 2019 7:30 am
Look closely at the left corner in that pic.
631-816-4911
9:00am - 9:00pm EST
gmrocket
Post by gmrocket » Sun Mar 24, 2019 8:37 am
Water flowz
Carnut1
Post by Carnut1 » Sun Mar 24, 2019 10:27 am
Water flowz
Slp runner, just extra air until I tig it up.
631-816-4911
9:00am - 9:00pm EST
gmrocket
Post by gmrocket » Sun Mar 24, 2019 1:53 pm
Water flowz
Do you not make any depth reference points when your grinding to reduce the chances of breaking through?
Carnut1
Post by Carnut1 » Sun Mar 24, 2019 3:14 pm
Water flowz
I use my sonic but it is difficult doing corners. Other times on something like this I just get carried away trying to get area or a shape just right. I certainly pay less attention on aluminum that will get welded anyway. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 » Sun Mar 24, 2019 3:22 pm
I should add that big aggressive burrs remove metal at a high rate of speed.
631-816-4911
9:00am - 9:00pm EST
Carnut1
Post by Carnut1 » Sun Mar 24, 2019 6:34 pm
After some testing I think this is my winner for overall flow in the lift range this engine will see. 2.02 Manley straight stem with a 32 degree back cut done on my Sioux 2001. They flow an amazing 13 cfm @ .15 lift more than a pro flow design with a necked down stem. It beat the pro flow design @.5" lift and equaled the same valve without a backcut.
Just head flowed with 1204 radius
From my phone so it did not make nice rows, sorry.
Pro flow nbc Straight stem. Straight stem bc
. 05. 38.3. 36.9. 37.4
.1. 71.7. 70.3. 72
.15. 100.5. 106.2. 113.4
.2. 134.1. 143.2. 143.3
.25. 164. 170. 170.5
.3. 192.3. 197.2. 195.1
.35. 215. 217.3. 217.7
.4. 232.7. 235.1. 235
.5. 255.9. 257.3. 257.3
631-816-4911
9:00am - 9:00pm EST
gmrocket
Post by gmrocket » Mon Mar 25, 2019 12:51 am
i used to do it like that too,, but unless you have photographic depth perception you just cant keep track of your cut depth unless you continually sonic over and over..way to tedious. especially if your shooting for the minimum wall thickness on a max port. doing about one sq inch at a time sure helps keep you focused on where you are in relationship to the original surface . ill never understand how some guys do a complete removal of the original cast finish, then go ahead and grind away on just about the whole surface area of the port at the same time.....its too much of an area to keep track of, unless its minor port work.
the way i do it now is actually way quicker and eliminates the chance of breaking through.... and it just about guarantees a uniform min.wall thickness. once you have you depth reference points done, you can go right at it with good pressure and an aggressive burr...
gmrocket
Post by gmrocket » Mon Mar 25, 2019 12:52 am
yup, and they bite more in the corners too.
Carnut1
Post by Carnut1 » Mon Mar 25, 2019 6:15 am
I can see that working for a port you have developed before but I can't see how that would work on a port you are still designing. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
