That car brings back memories. My best friend in high school had one with a 4 speed. It could run with SBC and some BBC Gen 1 camaros with ladder bars in a street race. But handled 2 times better.GARY C wrote: ↑Sat Mar 16, 2019 2:42 pmYes WS6, the car only has around 32,000 miles on it, it still had the Goodyear NCT tires on it from the article and from the looks of the rear tires I think most of those miles came from tire smokeSchmidtMotorWorks wrote: ↑Sat Mar 16, 2019 12:39 pmBy the looks of the wheels, that is has the WS6 suspension package.
If everything is kept tight, that is a pretty good handling car
and
the engine bay that is easier to work on than late model cars.
It still has original space saver spare, jack and hard ware, t top bag.
MCS Length?
Re: MCS Length?
Re: MCS Length?
and
Re: MCS Length?
Wow! Nice score! Good luck getting it back together and running the streets! Looking forward to that day already.GARY C wrote: ↑Sat Mar 16, 2019 2:42 pmYes WS6, the car only has around 32,000 miles on it, it still had the Goodyear NCT tires on it from the article and from the looks of the rear tires I think most of those miles came from tire smokeSchmidtMotorWorks wrote: ↑Sat Mar 16, 2019 12:39 pmBy the looks of the wheels, that is has the WS6 suspension package.
and
Re: MCS Length?
This is my 400 4spd car, I got this far but have not painted it or installed interior.SchmidtMotorWorks wrote: ↑Sun Mar 17, 2019 3:15 amThat car brings back memories. My best friend in high school had one with a 4 speed. It could run with SBC and some BBC Gen 1 camaros with ladder bars in a street race. But handled 2 times better.GARY C wrote: ↑Sat Mar 16, 2019 2:42 pmYes WS6, the car only has around 32,000 miles on it, it still had the Goodyear NCT tires on it from the article and from the looks of the rear tires I think most of those miles came from tire smokeSchmidtMotorWorks wrote: ↑Sat Mar 16, 2019 12:39 pm
and
Re: MCS Length?
Sort of an update!
Dismal flow numbers that should please The Choir Boys!
MCS speed if my numbers are correct around 411 fps as ported.
Re: MCS Length?
Trying to reduce Reduced entry and it's effect on MCS, Entry to small and carried into MCS slightly raised speed to 456ish at MCS.
Peak flow was down about 10 CFM.
Re: MCS Length?
Working my opening and MCS brought my speed back under control as well addressing some of the dismal flow numbers making them less dismal. Also the preliminary ex FLOWZ.
I am not getting to involved in changes because I am not using the final valves yet so I don't want to make any big changes. I also found some small areas to fine tune that brought speeds down a touch but no real chang in CFM.
Re: MCS Length?
Gary,
couple of questions
what is the pinch set to as in size?
what air speed at the pinch,intake floor and SSR at the apex do you have?
what test pressure ??
my eyes opened when i started testing at 35''-40''of depression,i think if you test at lower test pressures and convert to higher depression it will be misleading.
did i see 292-191 cfm on your sheet of paper??
couple of questions
Re: MCS Length?
Pinch is about 1.937... Mid port about 2.36... Short turn about 2.66... Throat is 2.51ishsteve cowan wrote: ↑Wed Mar 20, 2019 4:29 am Gary,
couple of questions
Head flowing at 7", Pinch is around 408, Apex around 397. I was not as concerned about actual numbers, I was more focused on how the opening affected the pinch.
The 292 on the last sheet is at .700, not sure on the 191 unless you are rounding up the 190.34, I have 2 different back cut ex valves I am looking at, the ex will go 207.
Re: MCS Length?
That sure seems fast but I guess if it goes where it's supposed to go, that's a good thing. That whole "stretching molecules" thing does come to mind, though.
Re: MCS Length?
My numbers could be off, I am not so sure about the pitot tube conversion thing, I will try to get correct on my sizes and as much as I hate to I will probably end up epoxying the throat area.
Re: MCS Length?
Gary,
i would set the pinch bigger say to 2'' 6500rpm peak ??
that would bring airspeed down slightly,throat @ 90% now where do want it ??
have these heads had a valve job yet,i would think with liquid boost the port would choke earlier if the port is to fast,
has the SSR been shaped much from cast,what cc is the runner after they were ported by some one else?? sorry for all the questions just trying to paint a picture in my mind
Re: MCS Length?
It will most likely end up in a street car that spends most of it's life between idle and 4000 so I trying to target 1.95 and 6000 to keep the head at or below 200cc, I would prefer to be more in the 87% range on the throat.steve cowan wrote: ↑Wed Mar 20, 2019 1:39 pmGary,
Port work and valve job are done, mild work on SS and I will probably do a little fine tuning along the way.
Re: MCS Length?
Gary,
Thanks for the confirmation, I think the pinch and throat size for your application that you suggest is a good idea,
Good luck with the build and hopefully get it together soon
Re: MCS Length?
Thanks, for what I'm doing I could probably run them like they are and have a decent running engine but my brain wont let me.steve cowan wrote: ↑Wed Mar 20, 2019 8:52 pm Gary,
