Dry Sump Suction lines
gramps
Post by gramps » Thu Apr 11, 2019 5:37 pm
What is the best type hose to use on the suction side of the dry sump pump? How many inches of vacuum does the pump pull? An16 out of the pan, AN10 out of the valley.
KnightEngines
Re: Dry Sump Suction lines
Post by KnightEngines » Thu Apr 11, 2019 6:52 pm
I use speedflow 200 series teflon braid.
1972ho
Post by 1972ho » Thu Apr 11, 2019 8:03 pm
Are you talking about the scavenging lines on the pan or pump suction line on the tank.
gramps
Post by gramps » Thu Apr 11, 2019 8:27 pm
As said 2 AN12 out of pan, 1 AN10 out of valley.
fast_crew
Post by fast_crew » Fri Apr 12, 2019 6:31 am
We've never had a problem just using pushlock type hose and fittings. If using stainless braid hose and reusable ends, avoid the o-ringed swivel type ends as we've had them suck air after getting some time on them. The amount of Vacuum pulled all depends on the amount of blow bye. Cast or aluminum block, alcohol or gas?? Steam created is the same/worse than "blow bye" when it comes to evacuating the crankcase.
Josh K.
leahymtsps
Post by leahymtsps » Fri Apr 12, 2019 6:49 am
Personally I use Brown and Miller and they claim you should use their braded stainless especially if more than
20". I do know there are some running their hi - temp non stainless below 15".
Some in Nascar are drawing up to 28" with the oil pump.
Tom
midnightbluS10
Post by midnightbluS10 » Fri Apr 12, 2019 7:21 am
Is the push-lok hose designed to be used with hot oil, though? Most of the stuff I see says not to use it for suction hose because it's been known to suck closed.
JC - Precision Guesswork & Expert Up Arrow Manipulation
Coloradoracer
Post by Coloradoracer » Fri Apr 12, 2019 7:50 am
I'm using the lightweight black braided hose, -12 in size...more flexible and no issues with collapse. Four stage system here, plus vacuum pump.
Mark Goulette
Authorized Amsoil Retailer
houser45
Post by houser45 » Fri Apr 12, 2019 9:45 pm
Dont use push lock on the suction side. It will pull shut
gramps
Post by gramps » Sat Apr 13, 2019 9:20 am
Looking at using Fragola Premium Black Nylon Race Hose suppose to be good to 28in.hg.
