It don’t matter
1972ho
It don’t matter
Post by 1972ho » Fri Apr 12, 2019 3:31 pm
http://www.thedrive.com/the-hammer/1276 ... decade-ago As far as which motor oil you use and long as the viscosity is right.
GARY C
Re: It don’t matter
Post by GARY C » Fri Apr 12, 2019 3:57 pm
For the most part that is true, If that is the test where they used taxi cabs they did say their test could not confirm cold start or performance engine conditions and newer VVT and cylinder disable are sensitive to oil weight.
ClassAct
Re: It don’t matter
Post by ClassAct » Fri Apr 12, 2019 4:17 pm
First off, consumer reports is about worthless. As for the article, I didn't read it because it has nothing to do with performance. It was junk daily driver junk.
Second, I've tested enough oil to know they all are not the same. Cheap oil is cheap and that's the best you can say about it.
GARY C
Re: It don’t matter
Post by GARY C » Fri Apr 12, 2019 4:54 pm
Can you share your test procedures, length of tests for each oil and your findings?
novafornow
Re: It don’t matter
Post by novafornow » Fri Apr 12, 2019 5:11 pm
I have used Blackstone many times, and for daily driver stuff I believe that they are correct. That is not applicable for towing race trailers up mountain grades at elevated temps. and I firmly believe that it is not applicable to high RPM race engines. But, each of us pays our money for what we each feel gives us the best value. I said value, not price. They are rarely the same.
GARY C
Re: It don’t matter
Post by GARY C » Fri Apr 12, 2019 5:35 pm
Yes there are enough good oils out there now days that trying to save a dollar makes no sense, In the one test I saw they detailed 100 engines in NY Taxi Cabs and ran them 75,000 miles because they almost never turn the cars off and sitting in bumper to bumper traffic, stop and go is considered hard on oil life and the only measurable wear was non certified and recycled oils and even those were almost unmeasurable.
It could have been 75 taxi's for 100,000 miles.
exhaustgases
Re: It don’t matter
Post by exhaustgases » Fri Apr 12, 2019 8:16 pm
Right on, good old wigwam oil kept many old junkers on the road back in the day around here.
Roundybout
Re: It don’t matter
Post by Roundybout » Fri Apr 12, 2019 8:18 pm
My wife's car has gone 215,000 miles on nothing but Walmart Supertech, changed every 7500-10,000 miles. Doesn't use more than 1/2 a quart in that time and still runs fine. I have no idea what the inside looks like but I'm curious and will take a peek when it finally dies lol.
As far as performance I'd be surprised if there was more than a 1-2% percent difference in HP between crappy oil compared to a top tier Amsoil for instance. Going from a dino to synthetic might be a little more. There is more to be gained by using a thinner viscosity if able than any additive differences between oil brands. Oil cleanliness is much more a factor in today's oils in reducing wear than the brand.
cab0154
Re: It don’t matter
Post by cab0154 » Fri Apr 12, 2019 8:26 pm
A buddy of mine tried that with his wifes lexus. He was running M1 0w20, but thought why not run the cheaper walmart stuff. It says its the same. With M1 the car was doing fine on 10k mile OCIs. 1,500 miles on the oil the engine started making a knock noise. So he went for broke and just changed the oil again back to M1 and problem gone. So I would not go so far as to say brand doesnt matter.
"Anyone who thinks the low RPM engine will be faster just does not have as much experience as the rest of us" -The late, great Joe Sherman.
ClassAct
Re: It don’t matter
Post by ClassAct » Fri Apr 12, 2019 10:15 pm
It depends on the engine but it's not hard to find 10-15 HP with a good oil. There are more good oils now than ever before. I don't consider Amsoil one of them. Even if you find 5 HP, where did it come from? It has to come from reduced friction. Anyone testing oils of different grades is a fool.
Dave Koehler
Re: It don’t matter
Post by Dave Koehler » Fri Apr 12, 2019 10:19 pm
BTOG called.
GARY C
Re: It don’t matter
Post by GARY C » Fri Apr 12, 2019 10:25 pm
I don't know the car but the 0w20 makes me think it has either VVT or cylinder disable capability or both... Some time back talking to Brian with BND about his own custom blended oils he said that regardless of how good the oil was if he got past about a 3w27 his cylinder disable system (Dodge Hemi) would start acting up.
GARY C
Re: It don’t matter
Post by GARY C » Fri Apr 12, 2019 10:32 pm
I don't know if it's legal to bet here but if it is I will give you $1000.00 dollars if you can prove 10-15 horse power on oil alone with the average performance build!
I have seen the claims and I have changed oil on the dyno and 0 to .5 would be more likely the power gain seen on average.
DV and others claim 5 hp from Oil Extreme... So where did it come from?
GARY C
Re: It don’t matter
Post by GARY C » Fri Apr 12, 2019 10:37 pm
BTOG called.
BTOG? Big Tongue Oppress Girls?
ClassAct
Re: It don’t matter
Post by ClassAct » Sat Apr 13, 2019 1:09 am
It will cost you more than 1k to test oil. The top 5 oils are less than 2 HP apart. The other oils there is plenty to be found. I've seen some horrible test methods where a junk oil is very close to the test oil because the test was improperly conducted.
You see power gains where you have bushed rockers rather than needle bearings (there is still power there) and things like triple springs will find HP with good oils. You also see much longer valve spring life. But no one likes to talk about that.
So gather up your cash and do your own testing. It's not cheap. Or just keep running Walmart shit and tell us how good it is.
And I don't know what DV is peddling. If it's an additive I won't even test it.
