0.5 Runner diameter is reasonable but that is dead space, not desirable on a carbureted manifold.
This is one of the reasons that manifolds usually have an X shape rather than H.
Another reason is runner length.
This is well said, and explains the issue that some see between the center 4 and outer 4 runners.Tuner wrote: ↑Sat May 25, 2019 6:00 pm Who recalls the distribution problems contestants encountered in the 2012 BLP Carb Shootout with single carbs on the tunnel ram type intake that had a long rectangular box plenum with parallel 90 deg. equally spaced runner entries, as opposed to the "X" layout of the Victor type intakes. The contestants supplied their own carb mounting plates that attached to the rectangular plenum with the carb situated in the center over the center four ports. The contestants using nearly flat lids had fuel distribution issues with the end cylinders lean and the center cylinders rich. The two contestants who used the same pyramid shaped lid had much better distribution and were the two top contestants in that portion of the shootout.
Was thinking more in reference to a tunnel ram, like his second manifold.SchmidtMotorWorks wrote: ↑Sat May 25, 2019 7:32 pm0.5 Runner diameter is reasonable but that is dead space, not desirable on a carbureted manifold.
You can fix fuel distribution issues with efi, but it will do nothing for the inherent air distribution issues in the single 4 version.
Off topic.. This is the general shape form of the 2x4 to 1x4 carb adapter. And the 6 venturi carb scheme to 1x4 bbl adapter. Nice and tall like this for a good transitiion.
Fix the end wall to runner opening situation, and cast the top with flanges for a Split Dominator....basically make a dual 2-Barrel deal out of it, might show some real promise.SchmidtMotorWorks wrote: ↑Sat May 25, 2019 7:32 pm0.5 Runner diameter is reasonable but that is dead space, not desirable on a carbureted manifold.
Not with those short runners or large combustion chambers.Ericnova wrote: ↑Sun May 26, 2019 3:14 amFix the end wall to runner opening situation, and cast the top with flanges for a Split Dominator....basically make a dual 2-Barrel deal out of it, might show some real promise.SchmidtMotorWorks wrote: ↑Sat May 25, 2019 7:32 pm0.5 Runner diameter is reasonable but that is dead space, not desirable on a carbureted manifold.
The headbolt pattern on an SBC is not compatible with a symmetrical port layout.Newold1 wrote: ↑Mon May 27, 2019 1:37 pm I think I know why but it always makes me wonder why back in the earlier days of aftermarket performance and racing cylinder heads why more SBC heads were not designed and built that utilized symmetrical port layout instead of perpetuating the poor design of a siamesed port head and then perfecting intake manifolds that crutched the poor heads with an intake that would slightly improve overall performance of these aftermarket heads.
The real answer, it was cheaper to design and build manifolds than design and build new better heads!
