Static Compression VS Dynamic compression
David Redszus
Re: Static Compression VS Dynamic compression
Post by David Redszus »
I found a use for Dynamic Compression Ratio other than to determine temperature and pressure.
DCR is directly related to Thermal Efficiency.
DCR......Thermal Efficiency
7..........54.32%
8..........56.50
9..........58.47
10.........60.26
11.........61.71
As long as compression temperature stays under control, shoot for a higher DCR.
Post by MadBill »
David, do those numbers take into account the Miller Cycle effect of a shorter effective compression stroke with an unchanging power stroke?
David Redszus
MadBill wrote: Thu Jun 27, 2019 5:02 pm David, do those numbers take into account the Miller Cycle effect of a shorter effective compression stroke with an unchanging power stroke?
Bill,
I kept the engine parameters unchanged and only changed the chamber volumes. I could have changed IVC as well.
The change in SCR did not matter since it is not used in the calcs.
GARY C
Post by GARY C »
David Redszus wrote: Thu Jun 27, 2019 4:25 pm I found a use for Dynamic Compression Ratio other than to determine temperature and pressure.
7..........54.32%
8..........56.50
9..........58.47
10.........60.26
11.........61.71
Between that and more cylinder pressure wouldn't that give a more complete burn of the fuel. The correct fuel of coarse.
GARY C
Post by GARY C »
David Redszus wrote: Thu Jun 27, 2019 6:02 pm
Bill,
Wouldn't changing the chamber volume change the SC?
David Redszus
GARY C wrote: Thu Jun 27, 2019 6:38 pm
7..........54.32%
8..........56.50
9..........58.47
10.........60.26
11.........61.71
Gary, the higher DCR values would produce higher temperatures and pressures, which should cause a faster burn rate, raising combustion peak pressure and advancing the burn angle. Yes, that should result in a more complete fuel burn which is important since we can only actually burn a quantity of fuel predicted by air mass and stoich value. We can't burn more but we certainly can burn less.
GARY C
Post by GARY C »
David Redszus wrote: Thu Jun 27, 2019 7:29 pm
7..........54.32%
8..........56.50
9..........58.47
10.........60.26
11.........61.71
Thanks, that kind of explains why cylinder pressure and DCR are looked at in reference to a pump gas engine that would be operating primarily at low rpm, high heat and on substandard fuel.
