Would anyone have any test data on the flow quality through the 90/05 style intake manifolds? Data on any year would be welcome.
I'd also appreciate any thoughts on the quality of the Mazda design.
Intake manifold air flow quality
Re: Intake manifold air flow quality
It might help if you put the engine in question in the title.
I THINK you mean mazda B engines, but not really sure, whats 90/05 mean?
You can likely answer a good portion of your questions yourself.
If you have the head and Intake from the motor in your post then get a set of expanding inside snap gauges and a cheap plastic dial caliper.
Take yourself some size measurements of the heads runner every 3/4" in along and do the same for the Manifold runners and you should get a good picture of where the choke points are.
A basic rule of Thumb is that any of the Manifold runners that have any line of sight going on with the heads ports will have a good amount more Intake flow taking place then others that do not have such!
https://www.flyinmiata.com/skunk2-ultra ... ifold.html
From the dyno charts you might be able to infer the level of the OEM design. As others have mentioned, you need to be more specific.
